Tough to move pallet forks
   / Tough to move pallet forks #31
My forks were really tough to move when I first got them so I removed the forks from the frame and took an angle grinder with a flapper wheel to the frame and forks and smoothed/buffed all the surfaces that came in contact with each other. I made a slight radius on all the 90 degree edges on the frame. Applied a thin layer of grease and now I can move them with just a slight push. Made a huge difference. I only tilt the forks down slightly to take any pressure off between the frame and forks. I found that tilting them straight down as some have mentioned would add friction on the back side of forks where they hook to the frame.
   / Tough to move pallet forks #32
Thanks however I just used a kit. I am in the forklift (related) business and this is a fork positioner mechanism from the forklift industry.
Works great for fork positioning but its not a clamp (load bearing) moves forks like a rocket ship.
Any chance you you can post a kit# and where to purchase it?
CANOE (A56859)
CANOE (A56859)
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
