How to connect a trailer w/drawbar attachment to my truck's receiver hitch?
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I have an off-road farm dump trailer. It uses a standard drawbar setup to connect to the tractor drawbar. I hook the trailer tongue to the tractor drawbar, insert a pin, and go.
I want to be able to reposition the trailer from one spot to another using my truck. So I need some way to attach the trailer to the truck, except it doesn't use a standard ball hitch. I think I need some sort of drawbar adapter that I can slide into the truck's 2" receiver hitch, and will prove a "drawbar" that the trailer will attach to.
I've looked around and can't find anything. Do you know of something that might work?
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #2
Clevis Trailer Pin Mount
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #3
I just use a regular ball mount without the ball.
That Clevis Trailer Pin Mount is perfect. I will get one at Harbor Freight. Lou, I did consider using the regular ball mount but I wanted some extra stability. I'm sure at some point I will be dragging a trailer full of wood on a slope, etc. so a little more stability would add peace of mind.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #5
This load is on a ball mount drawbar with either a 1" or 7/8" draw pin.
Is your trailer a clevis like the other drawbar mentioned, with 2 ears, one that goes above your tractor draw bar and one under it.
One item that can be a problem with two double clevis's is the limited movement in an up and down angle, the 4 holes will bind with any up an down travel.
And the larger the draw pin the faster the bind happens. Only one double clevis to a single draw bar.
Heavy farm trailers to very large tractors the tractor drawbar is a clevis to ring hitch on the wagon or trailer.
Normal tractor drawbars are a single bar, with the wagon or trailer hitches having a double eared clevis.
Yes the trailer has 2 ears on its hitch end.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #7
Then I would avoid the drawbar with two ears, it will bind up with up or down travel.
Enjoy
Hmmm. Good point.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #9
Enjoy
...or even side to side movement too.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #10
This is the way to do it. We towed farm wagons this way all the time.
I bought a spare trailer mount (no ball) at Tractor Supply yesterday. Got one with a 3" drop which I will probably instead use as a 3" lift. Will try it out soon.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #12
My question with those is about whether or not the holes will line up.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #13
Getting lined up and the proper distance can be frustrating, we have adjustable tongues on most of our wagons, the few that don't we like to use two people otherwise a lot of in and out of the truck.
I connected it up today. Worked fine. The pin is a little sloppy going through the trailer mount, but nothing alarming. Probably helps a bit as things flex.
My trailer is only a 2 ton, so I can move it up and around (sort of) to be hitched up.
Thanks again.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #15
If you have a piece of chain laying around you could add it with a threaded link if you're concerned about it possibly disconnecting.PPL_8056035.jpeg
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #16
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2018 Chevy Silverado 1500 4X4 (A61306)
2018 Chevy...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
206707 (A58375)
206707 (A58375)
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
20704 (A55853)
20704 (A55853)
