How to connect a trailer w/drawbar attachment to my truck's receiver hitch?
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I have an off-road farm dump trailer. It uses a standard drawbar setup to connect to the tractor drawbar. I hook the trailer tongue to the tractor drawbar, insert a pin, and go.
I want to be able to reposition the trailer from one spot to another using my truck. So I need some way to attach the trailer to the truck, except it doesn't use a standard ball hitch. I think I need some sort of drawbar adapter that I can slide into the truck's 2" receiver hitch, and will prove a "drawbar" that the trailer will attach to.
I've looked around and can't find anything. Do you know of something that might work?
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #2
Clevis Trailer Pin Mount
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #3
I just use a regular ball mount without the ball.
That Clevis Trailer Pin Mount is perfect. I will get one at Harbor Freight. Lou, I did consider using the regular ball mount but I wanted some extra stability. I'm sure at some point I will be dragging a trailer full of wood on a slope, etc. so a little more stability would add peace of mind.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #5
This load is on a ball mount drawbar with either a 1" or 7/8" draw pin.
Is your trailer a clevis like the other drawbar mentioned, with 2 ears, one that goes above your tractor draw bar and one under it.
One item that can be a problem with two double clevis's is the limited movement in an up and down angle, the 4 holes will bind with any up an down travel.
And the larger the draw pin the faster the bind happens. Only one double clevis to a single draw bar.
Heavy farm trailers to very large tractors the tractor drawbar is a clevis to ring hitch on the wagon or trailer.
Normal tractor drawbars are a single bar, with the wagon or trailer hitches having a double eared clevis.
Yes the trailer has 2 ears on its hitch end.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #7
Then I would avoid the drawbar with two ears, it will bind up with up or down travel.
Enjoy
Hmmm. Good point.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #9
Enjoy
...or even side to side movement too.
/ How to connect a trailer w/drawbar attachment to my truck's receiver hitch? #10
This is the way to do it. We towed farm wagons this way all the time.
Bobcat A770 (A60462)
Mini John Deere Truck (A55853)
Mini John Deere...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
