Loader Replacing Tilt cylinder rod
   / Replacing Tilt cylinder rod
I think I would pull the good cylinder off and use it for reference and then use a strap to hold the grapple where you want it. This will leak some oil, but you have to break the lines loose anyway on the bad cylinder. Get a helper and do it all manually and you have a shot at draining the oil into a bucket. I work for a loader manufacturer that used to supply Kioti. I know you are in a tough spot on the best way to fix it. When this happens it's often about as cheap to buy a cylinder. After you buy the rod AND seal kit that will be ruined taking the cylinder apart to repair it... If you are paying the dealer... you may as well buy the whole cylinder once labor is tacked on. If you can repair it yourself, I would buy the parts. My experience has also been that these companies are really proud of their parts.... the markup is nuts.
Really appreciate the input.
I've removed the bad cylinder and I'll also remove the good one. I'm capping the hoses and ports (on the cylinder), so little in the way of fluid getting dumped on the ground.
Lots of measurements to consider with these things! (I'll let the professionals review for possible matches.)
If anything, I've learned enough that I think that I could likely feel confident in doing a seal repair. This repair, however, has some unknowns in it: I may have the tubes checked and if they're OK I might then look to (if cost effective) rebuild to have a spare on hand.
I'm almost back in operation.
Had a local shop build a new rod and put it all back together with new seals. I brought them the good cylinder for proper measurements. Opening up and then putting together the good cylinder added about 1/2 hour: I have the measurements (had them make me a copy of their drawing), so should I break another rod I can save 1/2 hour of shop time and my time for removing and reinstalling the [good] cylinder.
I figure I saved about $125. Not a lot, but even if there was zero savings I'd still probably go this route as the shop is great: they know how to do customer service (my dealer is poor at, and my patience with trying to help them improve is running out).
Waiting on a new linkage assembly (original one is tweaked and I'd rather not risk it) and I'll put it all back together.
   / Replacing Tilt cylinder rod #13
DieselBound, glad to hear this is working out for you.
BTW, mind saying how the damage occurred in the first place? If only so I'll know what never to do? :)
Threepoint, I can only speculate what caused it as what I was doing when I noticed I had a problem (fluid pouring out!) wouldn't have been responsible for the damage, though it might have been the straw that broke the camel's back. Just prior to this operation I was trying to, using my grapple, dislodge a huge piece of tree trunk that was at the front and bottom of a pile (placed there with an excavator, though the excavator's lift capacity is only about 10% more than the NX and KL0610 loader). Trunk was odd shaped, a bit thick in height and I couldn't readily get under it (grapple opening) so I tried coming at if from the top. Going from the top I was, essentially, over-extending and driving a bit to get the grapple down and over the trunk. I suspect that this is what ended up bending the cylinder rod and then when I gave up on that operation I suspect that while adjusting the tilt the thing likely broke, only to fully eject bits with my following, light-duty operation.
Bottom line: DON'T push hard with full tilt! Lots of broken cylinders from back-dragging from what I've read, but same applies to going forward. In my case there's a fair bit more leverage with the long tines on the grapple.
When talking to the folks at the shop, who didn't think I merited being on any list of big screw-ups:D, showed me a twisted up rod from some Ford tractor that an operator had the bucket down scooping on concrete and hit an edge (of another section of concrete)- turned that rod (different metal) into a snake, a nice "S" pattern.
   / Replacing Tilt cylinder rod #15
Thanks for sharing this. I'm no engineer, but I agree with the folks at the shop. I can see myself doing something like this. :) With these heavier and more powerful CUTs, it's easy to underestimate the additional forces on the loader components due to inertia when the whole tractor is moving, either forward or in reverse. E.g., trying to dislodge a big stump with the bucket or grapple, or pulling a big broken limb out of a tree by backing up. I cringe when I think of all the things I've done or tried to do over the years with my 26 y/o B2150 and its FEL. Nothing short of abuse, actually. Except for bending the top of the bucket from misuse of a center slip hook, I guess I got away with it because the tractor is light. Shortly after I got it, a construction manager commented: "Know the limits of your machine." That made an impression on me, for sure, but for me it was kind of like saying: "Always do the right thing." I found myself always pushing to find what the limits were! :laughing: I'm much more careful with my newer tractors, even though the loaders are much more powerful and capable. Also, seeing the experience of other TBN members over the last four years has made me a wiser and more cautious operator!
   / Replacing Tilt cylinder rod #16
Aside from the cylinder seal blow-out, my B7800 has been indestructible. I've back-drug with the bucket curled (tilt fulling extended) even while lifting the front wheels! I've bounced the tractor with the bucket levered on something. Other than paint scrapes and some bent sheet metal, nothing is twisted of with issue: I've run it now for about 1,100 hours (over 1,800 total hours). If only everything else were built like this B7800: I won't part with this tractor!
rufdog, I look forward to watching those videos (bandwidth constrained right now).
   / Replacing Tilt cylinder rod #18
I once heard about a guy that tried to shove his pallet forks in the ground vertically, side by side to dig a trench by driving forward. You can guess how that worked out with the leverage of the forks...
On my Kioti I once stuffed my forks straight down trying to see if I could push myself up and back (was stuck). Ha, ha! Didn't work! Sank those puppies 4' into ground.
   / Replacing Tilt cylinder rod #20
I’ve about given up on having rods put back in cylinders. The last time I did that it ended up costing me more than the high priced Kubota cylinder. I think buying 2 generic cylinders and a can of orange paint would be cheaper. I wouldn’t feel good about just using a generic cylinder on one side unless it was an exact replacement. On the event that it probably isn’t using the same one on both sides would be better.
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
Club Car Utility Cart (A55853)
Club Car Utility...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
