Rhino TW72 parts
   / Rhino TW72 parts #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
My Rhino TW72 started vibrating really badly and after looking it over, one of the blades isn't swinging and the hub is missing a piece. Of course, I'm at my property and need the mower working so I can get my dove field planted. Are these parts fairly interchangeable or will they be cutter specific? Do you guys think I'll be able to get it fixed in a day or so or am I probably screwed for this trip?
   / Rhino TW72 parts #2
Did you ever find a parts source as I am looking for skid shoe assembly for my Rhino TW72 ?
The part number I have is from my parts manual, it is
Item 1, Part number 0622000001, Qty 2, Description Skid shoe (60 & 72).
   / Rhino TW72 parts
I ended up getting everything I needed at my local Lansdowne Moody. A larger tractor dealer that carries Rhino parts should be able to get you what you need.
My TW72 is good as new after the rebuild, I had to weld some plate over some thin spots but other than an occasional greasing, I just abuse it.
   / Rhino TW72 parts #4
My TW72 is good as new after the rebuild, I had to weld some plate over some things spots but other than an occasional greasing, I just abuse it.
Yes me too, I give it all my tractor will take. I just finished mowing 4 to 5 inch brush Have slip clutch adjusted just about right. The old TW72 are beasts. I had an old Brush hog years ago pulled it with my Cat RD4 When I came to Big Sage Brush with main stump 6 to 8 inches I would just run over it with my track to knock it down and then pull the hog over it. Only problem I ever had with it was it had 2 auto type tires, once I didn't see the old homesteaders Chicken wire on the ground and man the mower turned the wire into many 4 to 6 inch straight an an arrow and I had 20 or more little wire arrows sticking in my tires had to replace the tubes. The good old days in the hot desert sun.
Thanks will try a few more dealerships Thanks
   / Rhino TW72 parts
If that doesn't work, try calling Rhino direct, they might be able to help. Their parts number is 800-446-5158.
Good luck! I bet that the thing that finally does these in will be lack of repair parts.
   / Rhino TW72 parts #6
Thanks
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2019 GALYEAN...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
