Rhino TW72 parts
   / Rhino TW72 parts #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
My Rhino TW72 started vibrating really badly and after looking it over, one of the blades isn't swinging and the hub is missing a piece. Of course, I'm at my property and need the mower working so I can get my dove field planted. Are these parts fairly interchangeable or will they be cutter specific? Do you guys think I'll be able to get it fixed in a day or so or am I probably screwed for this trip?
   / Rhino TW72 parts #2
Did you ever find a parts source as I am looking for skid shoe assembly for my Rhino TW72 ?
The part number I have is from my parts manual, it is
Item 1, Part number 0622000001, Qty 2, Description Skid shoe (60 & 72).
   / Rhino TW72 parts
I ended up getting everything I needed at my local Lansdowne Moody. A larger tractor dealer that carries Rhino parts should be able to get you what you need.
My TW72 is good as new after the rebuild, I had to weld some plate over some thin spots but other than an occasional greasing, I just abuse it.
   / Rhino TW72 parts #4
My TW72 is good as new after the rebuild, I had to weld some plate over some things spots but other than an occasional greasing, I just abuse it.
Yes me too, I give it all my tractor will take. I just finished mowing 4 to 5 inch brush Have slip clutch adjusted just about right. The old TW72 are beasts. I had an old Brush hog years ago pulled it with my Cat RD4 When I came to Big Sage Brush with main stump 6 to 8 inches I would just run over it with my track to knock it down and then pull the hog over it. Only problem I ever had with it was it had 2 auto type tires, once I didn't see the old homesteaders Chicken wire on the ground and man the mower turned the wire into many 4 to 6 inch straight an an arrow and I had 20 or more little wire arrows sticking in my tires had to replace the tubes. The good old days in the hot desert sun.
Thanks will try a few more dealerships Thanks
   / Rhino TW72 parts
If that doesn't work, try calling Rhino direct, they might be able to help. Their parts number is 800-446-5158.
Good luck! I bet that the thing that finally does these in will be lack of repair parts.
   / Rhino TW72 parts #6
Thanks
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
