Stipping a B250 gearbox.
/ Stipping a B250 gearbox. #1
zonta223
Adelaide South Australia
Foton FT404, International 444 with forklift, International B250, Kubota L2000DT, Truck converted to all terrain forklift and lots of other junk
Looking for some information on removing the gearbox/diff assembly from the tractor.
Is it possible to remove the gearbox/diff assembly and leave the clutch assembly and bell housing still connected to the tractor?
Any help or guidance appreciated.
Goodness could not even spell stripping lol
/ Stipping a B250 gearbox. #2
If I am correct you needs to split at the clutch and remove a c-clip from the bottomshaftplug. Then remove that plug and a c-clip from the bottom shaft s tip.Now remove the pto shaft from the back and the pto selector from the leftside.
/ Stipping a B250 gearbox. #3
I think you may be correct for the B275 which has a dual clutch but my B250 only has a single clutch.
And both have some gears and shafts to drive the PTO
I'm sorry but you are wrong.
The gearbox on a single clutch plate B250 can be easily split from the clutch bell housing. leaving the clutch bell housing and clutch connected to the engine.
There are 2 external bolts and 6 internal accessible after you remove the inspection plate.
Remove these bolts and the gearbox/diff can be removed.
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
2022 EZ-GO ELITE...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
