Harbor Freight tools that DO suck
Status
Not open for further replies.
/ Harbor Freight tools that DO suck #121
I currently have Milwaukee M18 cordless tools and it's clear that they have limitations. Drilling holes over 1/2" in steel can be done but it takes a toll on the battery. If I have more than one or two I use a real drill. The same goes for saws. There's certainly places where a battery is much more desirable. When building my house before the power was installed it sucked having to listen to a generator run but I don't know of anyone making a cordless table saw.
/ Harbor Freight tools that DO suck #122
It looks like both DeWalt and Milwaukee offer one:
Cordless Jobsite Table Saw Head-To-Head - Tool Box Buzz Tool Box Buzz
Aaron Z
/ Harbor Freight tools that DO suck #124
The little shop type vac, 5 gallon is it? Maybe less. It sucks good, but tips over too easily. I may need to add some kind of feet to it. Hose is stiff too and doesn't bend very well, which is why I keep tipping it over.
/ Harbor Freight tools that DO suck #127
Battery powered devices don't pollute? They just transfer the pollution to the generating station that provides the power to charge them.
Not to mention the factory that built the batteries or the waste when the battery is spent. Not knocking batteries vs. other forms but I think many folks just see a 'clean' battery output and it has zero pollution impact.
/ Harbor Freight tools that DO suck #128
i gave the ratcheting pipe threader a try. stay away. my first 1/2 in black iron and i'm going along, gets real easy... casting around the dies disintegrates into a handful of cast iron bits. ohwell. traded it back in on a couple more furniture carts.
/ Harbor Freight tools that DO suck #129
This is good to know. I almost bought this threader, but ended up finding an old American made set on Craigslist for less $$.
/ Harbor Freight tools that DO suck #130
Wow. I bought the set that goes up to 2" in about 2003. I've only used the set for maybe 50 cuts overall in 1/2, 3/4, 1.25, 1.5" galvanized pipe, plus 2" PVC. No problems. I doubt the dies are anywhere near tradesman quality but this worked fine for the farm repairs I needed.
If it were me, I would wait until they have a different production run on the shelves then buy again. HF's Chinesium is random in quality. :)
/ Harbor Freight tools that DO suck #131
Agree with California that you should try again. I've had the 1/2" to 1" set for nearly 20 yrs. I haven't used it a whole lot, but I've never had a problem.
/ Harbor Freight tools that DO suck #132
Did I find a tool they don't have? No antifreeze tester???? I thought they had everything? How can I do a Do or Don't if they don't have one?
This is a Do.
/ Harbor Freight tools that DO suck #133
/ Harbor Freight tools that DO suck #134
I have one in the garage somewhere that's probably 30 years old or more. If I can even find it, I'm not sure it would still be accurate. Do they go bad?
I need to hit AutoZone today anyways, so ...
/ Harbor Freight tools that DO suck #135
I'm going to call this a 'Do', even only for a bad description. It may work fine, but there is nothing on the webpqage or box that says it has to be welded on. It even says hardware included. The picture isn't really clear about how it mounts either. One of the reviews mentions 'some welding', but isn't clear on what they mean.
2000 lbs. Capacity Swing-Back Trailer Jack Haul-Master®- item #69782
They have another one that's bolt on, so I guess I'll have to exchange it next time I go.
/ Harbor Freight tools that DO suck #136
I've probably bought and lost an antifreeze tester on an average of every five years for the last forty-five.
/ Harbor Freight tools that DO suck #137
You must be my brother from another mother!! I have a lot of duplicate tools. Out of necessity ��
/ Harbor Freight tools that DO suck #139
/ Harbor Freight tools that DO suck #140
Status
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
NEW HOLLAND TC35A TRACTOR (A64280)
NEW HOLLAND TC35A...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
7888SFL (A61567)
7888SFL (A61567)
Trimble 2050 Display Screen (A64119)
Trimble 2050...
