Harbor Freight tools that DO suck
Status
Not open for further replies.
/ Harbor Freight tools that DO suck #81
Just stumbled on this while looking at something else:
Name of product: Portland, One Stop Gardens, and Chicago Electric 14 inch electric chainsaws
Hazard: The power switch can malfunction and allow the chainsaw to continue operating after the operator moves the switch to the “off” position, posing a serious injury hazard to the operator.
Remedy: Replace
Recall date: May 14, 2018
Incidents/Injuries: Harbor Freight Tools has received 15 reports of chainsaws continuing to operate after being turned off by the operator, resulting in three laceration injuries including one serious injury to the arm requiring stitches.
Harbor Freight Tools Recalls Chainsaws Due to Serious Injury Hazard | CPSC.gov
/ Harbor Freight tools that DO suck #82
Hazard: The power switch can malfunction and allow the chainsaw to continue operating after the operator moves the switch to the off position
Oh great.
One thing we learned quickly with professional Skllsaws: never release the trigger while the motor is still under load. That welds the contacts together and the saw keeps running. I expect the same thing applies to any power tool from HF. Lift the saw or whatever out of the cut slightly before releasing the switch!
/ Harbor Freight tools that DO suck #84
Hazard: The power switch can malfunction and allow the chainsaw to continue operating after the operator moves the switch to the 登ff position, posing a serious injury hazard to the operator.
Remedy: Replace
It's only certain model numbers of the Chicago Electric and Portand 14". Recall was back in May. Was fairly heavily publicized then, but obviously not well enough. Had never had a problem, but returned my Chicago Electric in June for a new Portland. Local store will do the swap.
These are handy little saws for indoor trimming of bowl blanks in the shop, or light cutting outside near a power source. But my 40v lithium Lynxx 14" saw has pretty much made it a dust gatherer.
/ Harbor Freight tools that DO suck #86
A friend is a locksmith, has a store and sells safes. One older fellow bought a large heavy safe from him years ago and put his life savings in it in his garage.
One night his shop was broken into, thieves wrapped a chain around the safe and dragged it out with a truck. You could see where at some point they loaded it onto truck (winch?) and left. Never caught them.
My friends point was never assume a safe is safe! It should have been bolted to the floor.
/ Harbor Freight tools that DO suck #87
Yup, and with the lithium-ion impact wrenches becoming more and more powerful, it's safe to assume even that isn't a safe safe. :eek:
/ Harbor Freight tools that DO suck #88
Bolted from the inside. I should have clarified. Wherever the safe is needs an alarm system also.
/ Harbor Freight tools that DO suck #90
The black and yellow batteries (the ones on the free coupons) may be the most useless batteries I've ever encountered. Sometimes free items aren't even worth that.
/ Harbor Freight tools that DO suck #91
YMMV. Alkaline they're not. But the AAAs work fine for me in the free flashlights. The double AAs are ok for other small battery devices. I've not tried the C or D cell versions; no coupons for them, that I know of. ;)
/ Harbor Freight tools that DO suck #92
HF batteries are one thing I have never tried. I just assumed their lasting power isn't top notch and when I turn on a disposable battery powered thing, I generally don't have spares laying nearby.
/ Harbor Freight tools that DO suck #93
I got a batch of the free yellow AA's some 5 years ago and the first few I tried were completely dead. I gave the rest to a kid to try out in his toys.
Recently I got the free Yellow AAA's and they work fine in my cordless mouse. So they should be ok for the tv remote etc, anything that uses little power.
And today I got the free AA's. I'm going to try them in the free flashlights. We shall see... Nothing lost if they won't power the flashlights.
Be careful with any of HF's batteries. I've had a couple of the alkalines sweat, expand, release corrosion fuzz in tv remotes while the remote still worked properly.
/ Harbor Freight tools that DO suck #94
I always store my 3400 TLB on blocks for the winter (I go to FL.)
It is a mid size old TLB, and probably weighs almost 4T.
I only need to jack up one side at a time.
Got out my 25 year old 10T bottle jack, and it would not even lift one side (2T).
Decided I need a new jack. Drove to nearest HF (60 mi. round trip), and bought a new 12T HF jack.
12T should be serious overkill for 2T..... right?
Nope! The new HF 12T jack would not even lift 2T
Checked the hyd. fluid level, and even added a little bit more.
NO DIFFERENCE!
Used a Wally World 6T jack that I had forgotten I had.....it worked fine.
The HF POS is going back for a full refund, but I will not make a special 60 mile round trip just to do so.
I still need a new 12T jack, but don't know what I will get.
They are all made in China, and many sellers probably get them from the same supplier/factory.
/ Harbor Freight tools that DO suck #95
Why were you using a jack to put a tlb on blocks?
/ Harbor Freight tools that DO suck #96
The TLB has turf tires, and I don't like the soft turf tires sitting on a concrete floor for 6+ months.
I also jack up my Jeep, as well as my equipment trailer with a Cadillac stored on it.
I leave my Corolla, Suburban, and Ford 1920 stored, with just higher than normal tire pressures.
Maybe none of it is necessary,.... but it is just me!
The poor old 8n looks good, but just sits in the back, getting no attention at all.
I did not even start the 8n this summer.
/ Harbor Freight tools that DO suck #97
I knew why you did that. I meant why not use the backhoe stabilizers and loader to lift it up?
/ Harbor Freight tools that DO suck #98
TLB was already sitting in my Morton bldg. snug against an outside wall.
Could not put one of the stabilizers down without moving the machine away from the wall, thus sacrificing some floor/wall storage space.
I could have used one stabilizer, and just jacked the other side.
Either way though, I still needed a jack that would do the job, and the HF 12T was a complete flop.
HF POS will be returned tomorrow, as I have to go near HF tomorrow anyway.
/ Harbor Freight tools that DO suck #99
Kinda wondering if that 12T jack failure was a fluke. Maybe just a leaking seal on that unit. They seme to get good reviews, although I understand how you might not want to take a chance on another one if the nearest store is so far from you.
FWIW, my 20T HF bottle jack has worked very well. And five years ago, my 4T HF floor jack had no trouble liftjng each wheel (one at a time!) of a 15,000 lb motor home for brake service.
/ Harbor Freight tools that DO suck #100
Not wild about the 'free' orange and black gloves either. Stitching falls apart and the liner separates after just a couple of uses.
Status
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
Lockers (A62613)
Lockers (A62613)
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
