Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #6,621
At times a like button would be nice. I see a lot of things I like, but don't comment all the time. However, I do like it when other people comment.
   / Tractors and wood! Show your pics #6,622
That's when you at least can :thumbsup:
   / Tractors and wood! Show your pics #6,623
Here are some pictures of what I thought was an interesting tree to take down today. It is an old white birch that has heavy lean and the top is hanging out over that flagged red oak. The oak has no place to go and I would like it to grow so the birch had to come down.
In order to keep it from damaging the oak and to put it in a slot with good position for winching the birch tree needed to fall about 45 degrees CCW from it's natural fall direction due to the lean.
I used a Swinging Dutchman to change the direction of fall by 45 degrees.
The top of the tree fell into the tractor road which is here.
I cut the top off and pulled it out of the way and piled some branches good for small firewood. Then backed to the tree and rigged a snatch block so I could pull the tree onto the road from it's top.
The log is 42' long and 16" at the butt
Pulled the butt to the tractor and headed for the landing. Will get a Pallet log and some firewood as a bonus. Someone else may get a nice red oak after I am long gone.
gg
   / Tractors and wood! Show your pics #6,624
Very nice Gordan . . . thanks for the pics. :thumbsup:
   / Tractors and wood! Show your pics #6,625
Precision felling.:thumbsup: I usually like to bust the top out of the oak and a few others, then have it hang up.:laughing:
   / Tractors and wood! Show your pics #6,626
Those are the ones I don't take pictures of :laughing:
gg
   / Tractors and wood! Show your pics #6,627
View attachment 576238gg
I always called those trees grey birch. As for the red oak the squirrels and deer will benefit every other year or so. You have any white oak? I haven't cut one of those in 35 years, I cant remember if it splits as easy as red oak or not.
   / Tractors and wood! Show your pics #6,628
Very nice Mr. Gould, your felling technique & patience to stop & take photos to document the procedure are inspirational. Thank you.
   / Tractors and wood! Show your pics #6,629
You might be right on the Grey Birch. The load ticket says White Birch though which is good enough for me but could be White, Paper, or Grey which are grouped together. Yellow Birch is separate and easy to tell apart from White and Grey.
There are no White Oak up on this ridge land but there is some down in the Conn. River valley where it is warmer and only 6 or 7 miles down hill from here.
gg
   / Tractors and wood! Show your pics #6,630
White and gray also will hybridize. While the former was the mainstay of turning mills for years, gray birch is only good for pulp, and doesn't even qualify as regeneration when we are meeting the laws set out in the Maine Forest Practices Act.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
