Wood Splitter With Fast Hitch
/ Wood Splitter With Fast Hitch #1
Shaneard
Southern Virginia
Ford 4630, Two IH 140's, John Deere A
I traded for a Troy-Bilt Horse tiller years ago and it came with a wood splitter attachment. The wood splitter hasn't been used in some time, it is self contained all but the engine which is why you have to remove the tines and attach the wood splitter. I had a water pump with an 8HP Briggs & Stratton engine and decided to put the engine on the wood splitter instead of having to hook it to the tiller with is aggravating. I also decided to put a fast hitch prong on it to hook to the 140 making it quick and easy. I don't plan on splitting a bunch of wood since we heat with gas, the wood will be for the tractor rim laying in the yard we roast hotdogs and marshmallows with. I removed the plate for the reservoir tank so I can mount the engine then figure out where the tank needs to be.
Little portaband time and a lot of grinder time and the prong test fit is complete.
Got the hitch welded on. I left the flat stock sticking out both sides because I was going to brace it off each side. Then I decided to cut them off because the braces will be in the way of the power plant and I trust my welds that it won’t break apart. I decided to box in the upright piece to tie it all together and so I wouldn’t have somewhere for water to sit and create rust.
/ Wood Splitter With Fast Hitch #4
My brother-in-law had one of those Troy-Built Tillers with the Wood splitter attachment. He kept the splitter on it most of the time.
It was a great old design idea: multiple tool heads to fit on one engine, and the ability to motor it around as needed. I would not want to move it large distances that way, but it was perfect for his place.
Motor mount is done.
Started making engine to pump mount.
Engine and pump are mounted. Carb rebuilt on engine and running good. Now to mount the hydraulic tank and give it a whirl.
Hydraulic tank mounted. Got to bring some clamps and hydraulic fluid in with me tomorrow and we’ll see what happens.
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2016 Ford Escape SUV (A59231)
2016 Ford Escape...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2010 Cadillac SRX SUV (A59231)
2010 Cadillac SRX...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
DEUTZ MARATHON...
