Chevy 454 Motorhome engine problems
/ Chevy 454 Motorhome engine problems #21
Post deleted ,
was thinking this Motor home was old enough to have an HEI, but by 1999 they are completely computer controlled and have individual coil packs, There aren't any Q- Jets involved either this should be a sequentially injected engine...
Listen for the fuel pumps 2 second priming time and then continual run when the engine is running.
If you can't hear it when everything is working, troubleshooting will be tough, without test equipment available when the engine quits.
The fuel pump relay is a cheap thing to try , or at least have a spare...
they can reek havoc with many systems (everything from the fuel pump, horn , auto trans shifting to air conditioner) problems.. ask me how I know:laughing:
at least with Grand Cherokees 3 relays on different systems in 3 months...
/ Chevy 454 Motorhome engine problems #22
We had an ignition module go out in our pickup and it sort of did the same thing. It was fairly inexpensive and is inside the distributor.
/ Chevy 454 Motorhome engine problems #23
This might be off topic but my motor home has a Chevy 454. Twice now we've been running along fine for a couple hours and it just dies.
Plenty of fresh fuel and it cranks over well.
Towed to a shop ($$$$$) each time and then after sitting overnight or a couple days it starts and runs fine. The first shop was Chevy experts and changed the fuel filter and checked the pressure. They couldn't find any problem. We've logged about 400 miles since then and it happened again.
Sounds to me like vapor lock or intermittent fuel pump failure. Any help??
I know many here are very knowledgeable in all things mechanical.
I know this is an older thread but I did some searching and found this forum. I am having the same problem that you had in your motor home. I have posted on IrV2 forum and received some ideas. I have a 1992 Winnebago with a chevy 454 only 16000 miles. When going down the road runs great, after about 1-2 hrs pull off on a exit it dies. Put it nuetral starts right up go a little farther may die again. No power steering and very little brakes! Not Good. Put new fuel pump, fuel filter and ICV . Any ideas? Did You get yours fixed? Thanks
/ Chevy 454 Motorhome engine problems #24
Could be an emissions problem not venting the fuel tank. ??
Next time it happens take the gas cap loose and listen for a vacuum sound. Then see if it runs again.
/ Chevy 454 Motorhome engine problems #25
still waiting on Buggs67 to respond
/ Chevy 454 Motorhome engine problems #26
tried that no results. Thanks
/ Chevy 454 Motorhome engine problems #27
Possible ignition coil failing after it gets hot. If it sputters then dies I'd suppect a fuel issue maybe a collapsed fuel line (rubber). If dies all of a sudden then I would suspect ignition related.
Sorry; off line a few days.
It ended up being the crank position sensor. The connectors were old and partly corroded so it worked for awhile then would quit.
My regular mechanic found the problem/solution after it left me stranded twice.
/ Chevy 454 Motorhome engine problems #29
thanks, never heard of that before. I will talk to my mechanic about that.
/ Chevy 454 Motorhome engine problems #30
my mechanic says my engine (1992) does not have a crank postion sensor. thanks
/ Chevy 454 Motorhome engine problems #31
I don't know how I missed this thread in the past, but we used to live in a 1992 Bounder motorhome with the 454 gas engine. We were on our way from the Dallas/Ft. Worth area to the Odessa/Midland area on the Interstate Highway with little traffic when it just died and would not restart. So I unhooked the little car we were towing, when to the nearest town, found an old timer mechanic who suspected a clogged fuel filter, so he went with me, changed the fuel filter, and it started just fine. So we took off, made another few miles and it died again. That time I coasted off the first exit and stopped in a safe place. So we fixed sandwiches for our supper and ate, and then the motorhome started just fine. We made it on to the RV park where we were going to be staying a week or so while I did a gas leakage survey for the local gas company. So while we were there, I decided to change the spark plugs to see if that would help.
And when I got in the wheel well to where I could see that engine, I found a 6 wire wiring harness running just inside the frame rail, which made those wires too close to the exhaust manifold. The insulation on those 6 wires was all melted together.:eek: I went and bought some wire, cut out about 3 feet of all the existing wires, spliced in new wire, and routed away from the exhaust manifold, and never had another problem.
/ Chevy 454 Motorhome engine problems #32
Thanks I will check
/ Chevy 454 Motorhome engine problems #33
I decided to look at some old records and find that episode started on 3/6/94 a dozen of so miles west of Tye, TX on I-20. After replacing the fuel filter, I made 48 miles before it died again. And once we got to Midland/Odessa, I had to do a job that kept us there for awhile, so it was 4/1/94 before I found the problem and fixed it before moving on.
/ Chevy 454 Motorhome engine problems #34
THANKS
/ Chevy 454 Motorhome engine problems #35
If the engine dies and wont immediately restart until it cools down, I would suspect a coil. If always restarts immediately, I would suspect the ignition switch.
/ Chevy 454 Motorhome engine problems #36
BINGO I replaced the ICM and it seemed to solve the problem! Drove 80 miles stopped several times never stalled. Thanks to all!
/ Chevy 454 Motorhome engine problems #37
Congratulations! I know how good it feels to accomplish something like that.
Good for you.
Now all my gauges have gone dead (except speedo and tach).
Caterpillar 928F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 928F...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2017 Ford F-250 Ext. Cab Pickup Truck (A61573)
2017 Ford F-250...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
Caterpillar 330/330L Excavator Parts and Service Manuals (A63117)
Caterpillar...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
