load tractor with chain fall
/ load tractor with chain fall #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I bought a Ford 5600 from an auction. Tractor doesn't start and I need to load it on a dove tail trailer later this week. Anyone every use a big chain fall to winch a tractor onto a trailer?
/ load tractor with chain fall #2
I bought a Ford 5600 from an auction. Tractor doesn't start and I need to load it on a dove tail trailer later this week. Anyone every use a big chain fall to wench a tractor onto a trailer?
I've never wenched a tractor. I have winched things on to my trailer (18' Hudson w/ 2/ dovetail and ramps) using my $50 HF 2,500 lb rated winch.
I've only used my chainfalls for lifting.
It should work though.
HF has their 12K rated winch on sale for $300 w/ coupon
/ load tractor with chain fall #3
I agree with newbury the chain fall will work. I've used a $20 come-along with no issues but the process is slow, and as always remember to brake and chock the wheels if you need to adjust whatever you use to winch the tractor.
/ load tractor with chain fall #4
I loaded these logs by picking with engine hoist then pulling them onto trailer with cable com-along.
Took time but worked well.
You can still see the chain around the fat one.
/ load tractor with chain fall #5
When using a chain fall in the horizontal position it is always helpful to have a helper guiding the chain. Sometimes it can get hung up at the head end of the chain fall.
/ load tractor with chain fall #6
If I needed a chainfall for a wench on a trailer, I would look far and wide, until I found a much lighter wench!
I could lie and say English is my second language :laughing:
/ load tractor with chain fall #8
Two of the big ratchet straps will pull a pickup up a trailer but then having two people is nice then
/ load tractor with chain fall #9
Before electric winches were common, I used to see lots of 2500lb pull boat winches on trailers.
Bruce
/ load tractor with chain fall #10
I’ve done that before on an uphill grade with a truck that had disconnected steering linkage. It worked but I’d look far and wide to avoid that method.
/ load tractor with chain fall #11
Go for it. I have done it many times and works fine. Just make sure to keep it from rolling if you have to rehook
/ load tractor with chain fall #12
So either block the tractor on your rehooks, or
block the trailer, disconnect trailer, and pull tractor up on trailer with your pull truck? (Put a jack or blocks under tail of trailer so trailer tongue doesn't pop up when loading :eek:)
With second method, you can also anchor a snatch block at the front of the trailer and the pull truck is behind (and off to side of tractor), if the trailer height is such that the pull cable would scrape if pulled from the front. Be advised that you're now pulling the trailer backwards as much as you're pulling the tractor forward. Block accordingly.
/ load tractor with chain fall #13
The block and tackle method works well and is way faster. If you’re using something that can’t pull far enough like ratchet straps or a chain binder I use 2 separate chains or straps.
/ load tractor with chain fall #14
Get second vehicle to pull the tractor onto trailer while trailer stays attached to tow vehicle and have someone steer tractor and brake as well. Ive done block tackle as well with cable attached to tree base. OR snatch block attached to the trailer and other cable end on vehicle and moving trailer with tow vehicle pulling the disabled vehicle onto trailer. Used posts many times by one of my roll up doors to move broken down things onto my pad by myself that i didnt want to damage trying to push with loader.
One of the handiest things Ive found is my GoPro camera and ipad as a video monitor (slight delay) to use as temporary backup camera for gooseneck and regular trailers, watching for clearance on a ramp on trailer or loading ramp, speed bump clearance for my boat trailer and friends enclosed trailer
/ load tractor with chain fall #15
My 2 ton come-a-longs are indespensible and once you own one you will say the same. Northern Tool has a 5 ton that will do the job much easier than a chain fall. You can buy a 2 ton and do as I do,use a second cable and snatch block to double 2 tons to 4 tons.
/ load tractor with chain fall #16
Update, please. Did you get it loaded?
A hi-lift jack is also good for pulling:
I did get it loaded. The auction company rep told me that it didn't start. I was unwinding the hoist when a maintenance guy drove buy and said it would start if jumped. He drove up next to the tractor, hooked up the jumpers, and it cranked on the first revolution. I drove it right on the trailer.
I guess its my fault for believing the auction rep knew what he was doing.
/ load tractor with chain fall #18
Good deal :thumbsup:.
/ load tractor with chain fall #19
:thumbsup: A $150 battery would have raised price at least $2k. That auctioneer did you a favor announcing it wouldn't start.
/ load tractor with chain fall #20
no offense but whats with chaining to the tire/rim instead of suspension? just curious...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2004 Sterling Ambulance Truck, VIN # 2FZACFCS24AM53402 (A65563)
2004 Sterling...
