Snowblower Three point rear snowblower? Good, Bad?
   / Three point rear snowblower? Good, Bad? #11
3 Point hitch snow blowers work great. I used them for years on 1/4 mile long hilly driveways. Went to front mount on a small Deere as constantly backing up going down steep hill became a pain
Andy
   / Three point rear snowblower? Good, Bad? #12
In my experience, you can snow blow pretty quick, if you have driveway markers to border your drive. When I'm away from the house/garage, I normally run in low range, 2nd or 3rd gear.
As far as snow blowing in reverse, setting in the seat at an angle reduces the amount of rotating your head...this reduces the "pain in the neck" aspect, considerably.
There is a caveat using a snow blower though. If you have a cab tractor, sooner or later the rear window will be covered with snow. I don't have a rear wiper, so I'll need to stop occasionally to clean the rear window. If you have an open station tractor, sooner or later you'll be covered with snow.
Ski googles help a lot...tinted, glare reducing ski googles help a lot during the day...much better then sun glasses. This is true with a cab or an open station.
There are real issues when it comes to a front blower...with a caveat. Most front blowers require a mid-PTO...most are designed for a particular brand (and sometimes a particular model). So, if you sell or trade your tractor, there's a good chance you'll have to replace the snow blower. Another thing is front blowers are pretty expensive compared to a 3PH blower.
The caveat is one can buy a hydraulic powered front blower (hydraulics run off a 3PH PTO powered hydraulic power supply). These blowers usually have adapters for most loader brands. Of course, you're looking at about $15 grand for one of these.
I used the bucket on occasion, but this year I bought a front blade (snow blower on the 3PH) for those lighter (6-8 inches or less)...best of both worlds.
The front blade is a manual angle since I only have one rear remote (used for the snow blower chute rotation). Next year, I'll probably add front hydraulics to the blade...we'll see how help it does this winter...
   / Three point rear snowblower? Good, Bad? #13
I use a 7 1/2' QA plow to clear snow till about the end of February. By then I usually have some pretty good snow piles and then use a Lorenz 7' double auger 3 pt. blower to clear the piles.
If your driveway is gravel make sure your blower has adjustable height shoes to keep the cutting edge from digging up the gravel.
   / Three point rear snowblower? Good, Bad? #14
I had one for several years. I only used it when snow was DEEP. They are slow, don稚 leave banks at the edge of driveways and parking areas and have a place in high snowfall areas. But not for every storm, at least for me.
   / Three point rear snowblower? Good, Bad? #15
I have a WoodMaxx 60 inch rear blower and I like it fine. It does not have skid “shoes”, it has skid “plates”. The area of the plates makes it drag a lot on pavement so the tractor has to overcome it. It is not a big deal but it may wear pretty quick but so far its not a problem. Oh, it has a manual chute rotation and I don’t have a cab. I do wear a warm hat and ski goggles les so I don’t even feel the snow actually.
Oh, about looking in reverse: I look rearward to cut the edges, the rest I can just wing it because you can judge by the edge of the cut you just made.
   / Three point rear snowblower? Good, Bad? #16
Blowers are good depending on where you live. I live in N. Illinois and bought a rear Kubota blower. After four years of it collecting dust and only tried ONE time on 1" of snow, I sold it and bought a front blade for this year. If I lived in an area where decent amounts of snow was a sure thing every year, I'd have one, but certainly with a cab. The one time I used it, I got covered. Remember... you can't always blow downwind.
   / Three point rear snowblower? Good, Bad? #17
Looking at picking up a Woods 60 three point snowblower That has never been used. It s a great deal. But I致e never used a three point snow blower. Any input? Do you like yours?
If you get a lot of snow a blower is the best way to go. Less snow banks = less drifts to deal with.
A rear mount blower can be a pain in the neck especially if you have a small machine and not enough HP to throw deep cuts or wet snow. No cab lets you enjoy eating the snow while blowing it.
I suggest making sure the blower is wider than your tractor wheels and that it's a 2-stage blower with fan.
   / Three point rear snowblower? Good, Bad? #18
Another point, I had a Puma 64" on a 26hp tractor. Loved it. Replaced tractor with a 33hp, replaced blower with a LMS, broke tons of shear pins.. I was putting them on finger tight. A friend recommended wrench tight and viola! No more broken pins...
We get tons of deep snow, I use the FEL to cut the banks where needed, and clean around doorways. The blower never leaves high banks and we get 200"-300" per year.. Some years we get little, one year we got 11' in a little over a week!
A friend gets more than us, and he fought with his front mount blower all season because of the deep snow.. couldn't lift it high enough for his banks. I dig in with the FEL, dump it, then blow it over the 10' banks
   / Three point rear snowblower? Good, Bad? #19
I looked at a used Woods snowblower but for what the owner was asking for it I could buy a brand new WoodMaxx with hydraulic chute rotation and deflector so that's what I did. Having seen both the Woods and the WoodMaxx I can say the WoodMax is a heavier and better built unit. The steel is thicker and it is more reinforced than the Woods.
   / Three point rear snowblower? Good, Bad? #20
In all the years - 27 - that I had the blower, I always wished we would get a great, fantastic snow storm so I could really use the blower. We never did and the deepest I ever saw with the blower was around 30" - barely a challenge.
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2013 Buick Enclave SUV (A55853)
2013 Buick Enclave...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
TANK MANIFOLD (A55745)
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
