Need bolt-on flat cutting bar for 16" BX backhoe bucket...
   / Need bolt-on flat cutting bar for 16" BX backhoe bucket... #1
Johnkn
Laplata, MD
Kubota LX3310
I need to do some fine drainage work, does anyone make a Bolton flat cutting bar/edge to replace the teeth on a 16" BX25d BH bucket? Thanks
   / Need bolt-on flat cutting bar for 16" BX backhoe bucket... #2
I need to do some drainage work, does anyone make a Bolton flat cutting bar/edge to replace the teeth on a 16" BX25d BH bucket? Thanks
Have you considered just removing the teeth and using the existing flat edge of the back hoe bucket?
In soft not to rocky soil you would probably not experience bucket damage.
Yes, I considered it, I'd like to find one if possible, or just make one. Thanks
   / Need bolt-on flat cutting bar for 16" BX backhoe bucket... #4
The bucket probably has welded shanks that can’t be removed to leave a flat edge. The easiest thing would be to weld a bar on the bucket and cut it off when you’re done. Most buckets have the outside teeth angled out so you can’t remove the teeth with a bar welded on.
   / Need bolt-on flat cutting bar for 16" BX backhoe bucket... #5
I just took off the teeth on my 24" bucket. The lip is 3/8" with a wedge profile, for grading it works fine.
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
2017 Ford F-250 Service Truck (A55852)
2017 Ford F-250...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2023 PRATT ANYSIZE CHASSIS (A55745)
2023 PRATT ANYSIZE...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
