PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #11
The hydraulics being a little nosier after use is the fan turning on I believe, Mine does it after mowing I let it run while I empty the bagger, it cools off and the fan shuts off. Your engine sounds just like mine, I think your being paranoid.
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #12
If the vibration you feel is more like a cavitation, make sure that there is hydro fluid visible in the sight glass on the rear diff. It is hard to see, but the fluid is just slightly off clear and can be seen on the white sight glass.
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #13
The air intake is what is actually moving the most in that video and it isn't rigidly attached. Watch it compared to the the belt pulley under it......
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #14
It's possible something is wrong.
We can only speculate based on what we see.
There have been zero reported issues with these engines.
I suggest you go to the dealer, and see how the ones on the lot are.
Really good advice in the last sentence. Cheap and easy to do unless the dealer is a long way away.
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #15
The OP should ask the dealer for some names of others with the same tractor. Go look at them and see how other's tractors are for comparison.
I would feel better if others could post videos of theirs.
There aren't any tractors local and my dealer it not close. They didn't even have a tractors on inventory when I bought this one.
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #17
Just went out and started mine and took a video, looks and sounds exactly like yours.. I don't know how to post videos, says it's the wrong kind of file.. If you want to PM you're phone # I can text it to you..
Inboxed you.
Thank you!
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #19
Video sent.
/ PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #20
Where are you ? There has to be similar machines somewhere within a reasonable drive to go listen to. This is so subjective you really need a couple of other machines to calibrate your judgement with. At the same time, SOUND is a very important, often profound indicator of "something ain't right" and I certainly understand sticking to your guns until this gets clarified. If you bought it brand new (seems you did) then the dealer should be willing to do a drive by and listen to it for you (as opposed to hauling it anywhere.) Also, enlist a friend or too with small tractor experience and have them listen.
Your air intake in the video shakes EXACTLY the same as mine on a Kubota BX2200. I eventually added a generic "full of holes metal strap" bracket lined with an old bike inner tube to try and quiet the shaking of the air filter assembly.
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2012 John Deere 8235R (A60462)
2012 John Deere...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2017 Ford F-550 Bucket Truck (A61568)
2017 Ford F-550...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
