PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #1
Nacademus
Gold Member
Rural, Ohio
Massey Ferguson GC1720
Hey there,
I'm quite new and recently posted a thread about my new tractor. I'm tossing this one up with the hope of getting some insight on what I should do about an issue I'm having.
I just took ownership of this tractor about 10 days ago. Only ran it around the yard, idled it a little bit, learned the backhoe controls and just familiarized myself with it.
The weather had been bad for a few days and today I was finally able to try and mow my 4 acres with it. My land is basically flat and grassy.
Everything was going great at first. It was smooth and went through the field-cutting like it wasn't even trying. It was a lot of fun and I enjoyed it. I wasn't cutting fast at all or really taxing the tractor.
About an acre in, I noticed that it was maybe a little weaker and felt different. I could hear the HST a little more, or maybe I was just noticed it more once it seemed to begin acting up. I stopped and let it idle a bit. I noticed that there was quite strong vibrations being transmitted through the whole tractor. My PTO was disengaged and I was on smooth concrete.
I opened the hood to take a look and the engine was vibrating a lot-more than it did before. It is very strange. The engine was barely operating at the first line on the temp gauge.
The vibrations happen at all RPMs. I will share a video to show what I mean.
I am feeling a little sick to my stomach and heart-broken about this tractor, now. I haven't even made my first payment yet :( I plan to call the dealership in the morning. I don't really know what they will do for me- probably charge me a fee to come get it for nothing.
The engine was sooooo smooth before. I remember specifically being very impressed with how a 3cyl diesel could idle so smoothly. Something is definitely wrong. Could it be a miss? Have there been any reports of issues like this?
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #2
It doesn't seem to be any different than mine, the temp gauge is normal, the way the fan setup and cooling system is on these GC's you will probably never overheat it.. Mine vibrates about like yours does..
I swear it wasn't that bad before. Maybe I'm being paranoid??
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #4
The smaller the engine the more they vibrate. You may just have not noticed it, the trans whine is probably normal as well just took you a while to start hearing it with it being a new tractor.. I would just check your oil and make your sure your hydro fluid level is at least half way up the glass near the rear PTO..
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #5
Also if you move you're throttle up to 17-1800rpm's it will smooth right out..
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #7
If I knew how to upload a video I would go out right now and show you mine..
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #8
It looks like mine does.
It's a 3 cylinder engine, they are inherently unbalanced. That's why you don't see a lot of them in cars.
It's a tractor, engines are mounted more solidly, and thus going to have vibration, even if the engine was balanced.
It will vibrate more at some rpm's than others.
I don't think this video is doing much justice. It did not vibrate in this manner earlier in the day. I guess I'll just wait it out until parts start shaking off. This cannot be acceptable.
   / PROBLEM HELP! 2018 GC1720 only 6 hours and developed a strong vibration #10
It's possible something is wrong.
We can only speculate based on what we see.
There have been zero reported issues with these engines.
I suggest you go to the dealer, and see how the ones on the lot are.
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2012 International Prostar (A56438)
2012 International...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
