3-Point Hitch hydraulic top link
/ hydraulic top link #1
alflen52
Member
wayland,mi.
new holland 25s
have read a lot of comments about hydraulic top links,seems like it would be a handy addition to smaller tractors,with the limited lift they have.doesn,t seem too difficult,just a cylinder of the right size and hoses.anybody done this?
/ hydraulic top link #2
I've not done it but I love the idea of it. I just acquired an International 1066 that was a dedicated mowing machine so its top-link is missing. (I bought it to also use as a mower). If I get a box blade for it, I'm seriously considering both top & tilt for it. Until then....I'll just keep the $$ in my pocket, I don't want to spend the funds if I end up not using tractor in that capacity.
/ hydraulic top link #3
Plus a control valve and connectors (rear remotes) on the back of the tractor.
/ hydraulic top link #4
I just installed a 3 spool valve on my 1620 for top, tilt, and a pair of quick connects for whatever. Using the top link with my boom pole for logging has been a godsend, the range of motion is doubled. I've only graded the driveway once so far, but it made the job soooooo much more efficient being able to dial in the right angle instantly while in motion.
Top link was only $155 from dalton hydraulics and the side link 1.5x4 cylinder from magister hydraulics was only $86. I'm going to cut the ends off my fixed link and weld them to the cylinder.
Here's pictures of my setup.
https://www.tractorbynet.com/forums...rating/402176-adding-rear-remotes-1620-a.html
/ hydraulic top link #5
The right size cylinder also has to have the right ends on it:
/ hydraulic top link #6
I had a hydraulic toplink with 2 remotes installed on my Kubota when new. My reasoning for the hydraulic toplink was I didn’t care for constantly adjusting the toplink when changing implements.
It’s a nice feature, but mine leaks down so I have to keep an eye on it t when the mounted implement needs to be at a certain angle.
/ hydraulic top link #7
I bought a hydraulic top link five years ago. I upgraded to my current tractor - 2009 Kubota M6040 - new, in 2009. Slowly but surely I've "chewed on the bullet" and traded in and/or sold all my class 1 implements - replacing them with class 2.
There are a lot of things that can be said about class 2 implements - the word seldom heard - - cheap.
So - after hundreds of trail/error on getting these ground engagement implements to work up to their expected level - I got the hydraulic top link. What a dramatic change - - I now am able to make finite adjustments while on the go. I no longer have to accept - "well, that's good enough". I tweak that hydraulic lever until the implement is performing at its very peak of efficiency.
I am now able to do things with my ground engagement implements that I never thought was possible.
I got my hydraulic top link from - Brian at FitRiteHydraulics.com He is a member of TBN - Mtn View Ranch.
Excellent piece of equipment - not a moments problems after five years of use.
that cylinder looks perfect,who makes it?
/ hydraulic top link #9
Strongly suggest you go with someone who sells hydraulic toplinks (and side links) with the double piloted check valves. I did not, and the resulting leakdown has had me regretting my decision for over a decade. One of these days I'll get around to replacing them with what I should have purchased originally.
/ hydraulic top link #10
I have been wondering.....the cost of the valve, tapping into the hydraulic circuit, and mounting it might be an issue for me....so....would it be acceptable to run QC hoses from the FEL curl function to the hydraulic top link. I am not experienced...a complete newbie....and have little knowledge of hydraulics. Or can I use a diverter valve, similar to what I have read about using the curl function to power a grapple? I think I can live without have the curl function on the FEL if it allows an easier and cheaper way to get a hydraulic top link.
I am wondering if tapping into the circuit to install a "normal" top link valve will have fluid spilling all over the place? Same issue with adding a diverter valve?
Seems to me a $200 cylinder and a few feet of hose will accomplish the same function at 1/2 the price. Yet, I like the idea of the diverter valve (adds more cost), if it is less money and easier to do, as if I needed to use the FEL I would not need to switch QC's. But is it just as much trouble/cost to install a diverter valve as doing it right in the first place?
Sorry for all the dumb questions.
/ hydraulic top link #11
i recently did it and love it. a lot easier then constantly adjusting and makes it easier to hook up implements. make sure you get one with check valves so no leak down issues
/ hydraulic top link #12
The problem I have had on using hydraulic cylinders to set depth/height is that as the fluid heats (for whatever reason) it expands causing the rod to extend beyond the set point, or if a leaker just the opposite. If you are on top of it, fine. If you don't pay attention it may mess up what you are doing. Numerous times I have replaced a cylinder with a ratchet type spiral device.
/ hydraulic top link #14
Something to consider about a top or side link with anti creep/locking valving is that you cannot float them. Depending on what you're doing, it may or may not be a big deal.
I purposely put my system together so I can float both top and side links to maintain my crowned and sloped driveway shape instead of cutting into it. As a creep test, I put my boom pole all the way up with about 100lbs dangling on it with the top link as short as it goes. Over 2 days, the top link has crept out about 3/4-1". That's not nearly fast enough to cause any kind of issue when grading a driveway or carrying a log on my boom. Obviously, your resruls may differ with other valves and cylinders. Maybe I just got tight ones?
This is the cylinder I used Dalton CAT-I Top Link Cylinder 2 Bore x 8 Stroke - Dalton Hydraulic
/ hydraulic top link #15
Not really an issue for me. My manually adjustable top and side links didn't float either, and none of my implements are designed for such use. I'm not even sure how I'd maintain a crown if my side link were "floating". It seems as though it would just float to follow the existing crown. Having never used such a system, I'm sure I must be missing something.
/ hydraulic top link #16
The two most common tools (for me anyway) you would use float on are box blade or land plane/scraper. Could also be used with a bush hog/rear mower to help keep the mower in constant contact when cresting a hill or ridge. Float is in the same category as as hydraulic top link itself, it's not remotely necessary to do a job, but it can make certain jobs much easier.
/ hydraulic top link #17
The two most common tools you would use float on are box blade or land plane/scraper. Could also be used with a bush hog/rear mower to help keep the mower in constant contact when cresting a hill or ridge. Float is in the same category as as hydraulic top link itself, it's not remotely necessary to do a job, but it can make certain jobs much easier.
It would be absurd to put a HTL in float position when using a box blade IMO...
BTW...three point hitches are always in float position unless draft control is present and set...
/ hydraulic top link #18
Absurd or not by your opinion, I have lots of elevation changes and 3 drainage cuts across my driveway. It winds uphill and is somewhere around a 20-22° angle which necessitates the drainage cuts/ditches. With a fixed top link set for finishing, I found I hand to constantly have my hand on the 3pt lever and keep an eye on the blade and adjust as needed. With the floating link, dropping the 3pt lever all the way down and letting the top link float lets the blade better follow my terrain changes with far less digging in hard at the bottom of my drainage cuts. I'm not talking about heavy grading or moving dirt, just gentle finish smoothing when I don't want it to dig in. My soil is also 80% sand which doesn't help things, so what works for me in my unique situation may not work for you in yours.
/ hydraulic top link #19
Absurd or not by your opinion, I have lots of elevation changes and 3 drainage cuts across my driveway. It winds uphill and is somewhere around a 20-22ー angle which necessitates the drainage cuts/ditches. With a fixed top link set for finishing, I found I hand to constantly have my hand on the 3pt lever and keep an eye on the blade and adjust as needed. With the floating link, dropping the 3pt lever all the way down and letting the top link float lets the blade better follow my terrain changes with far less digging in hard at the bottom of my drainage cuts. I'm not talking about heavy grading or moving dirt, just gentle finish smoothing when I don't want it to dig in. My soil is also 80% sand which doesn't help things, so what works for me in my unique situation may not work for you in yours.
Whatever floats your boat...but a box blade is NOT an attachment where a hydraulic top link in float is commonly applicable...
/ hydraulic top link #20
You can definitely use a loader curl circuit to control the top link. But you would either need to always be changing over hoses, or add a diverted valve. But it is a cheap starting point. Do it that way will get you in the hydraulic top link game and you can then decide if you want to add a diverted valve or a dedicated circuit. If you do decide to add a dedicated circuit add two, cheap to do at the time and you never know what the future holds. .
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Chipper Insulated Bucket Truck (A61573)
2020 Freightliner...
2013 TIGERCAT 720E FELLER BUNCHER (A64276)
2013 TIGERCAT 720E...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
