any toro groundsmaster fans on here?
/ any toro groundsmaster fans on here? #461
Asymair95, last thing first, it is a forward only overrunning clutch. The full time clutch is cable operated by a lever next to the seat.
First thing last, I can't tell for sure about the decks without a serial number plate, but I know that I wouldn't do the swap, but that is just me.
/ any toro groundsmaster fans on here? #462
The clutch looked different than ones I had seen on here. It has a grease zerk instead of a plug for gear oil.
The thought of having a brand new deck shell is appealing, particularly considering the price he wants (cheap). Why wouldn’t you do it? Too much of a chance things wouldn’t fit?
/ any toro groundsmaster fans on here? #463
Yep, saw that zerk. Hope it didn't get greased, I don't think it will work with grease in it.
I wouldn't do the swap, because I am old and lazy and can afford to buy a new or good deck.
/ any toro groundsmaster fans on here? #464
I was hoping it was a different kind of clutch as it doesn’t look as big around as the gear oil lubed type. You can tell the shaft had broken at some point also because there is a dent in the oil pan.
/ any toro groundsmaster fans on here? #465
To me it looks like my 325D one way clutch:
This is the larger diameter bi-directional clutch on the 328D:
But you triggered something way back in the dark corners of my memory. Seems like there is a kit that eliminates the clutch and hooks the driveshaft directly to the rear differential. Probably not recommended for hard surfaces.
/ any toro groundsmaster fans on here? #466
Yup, that bottom pic is the one I was thinking of with the gear oil in it. Does your other clutch pictured above have a grease zerk too?
/ any toro groundsmaster fans on here? #467
Yep, the 325D has the zerk, Rotated the driveshaft and shined the flashlight on it:
Edit: Copied from service manual "Lubricate clutch through grease fitting (Item 32) with No. 2 General Purpose Lithium Grease."
/ any toro groundsmaster fans on here? #468
Cool thanks.
Has anyone put wider tires on these for better flotation over soft ground? I see 23x10.5x12 was an option for these. Would something wider fit?
/ any toro groundsmaster fans on here? #469
Check your rear bushings. They are supposed to be checked every 500 hours IIRC.
Mine were gone. I had to rebuild the steel and have it line bored. There was no way to just drill out the egged out holes and have everything turn out correctly. It's a ton easier to check the bushings & pin and change them as needed.
I don't much care for the bi-directional clutch. Is the a rear differential that could be used for a full time 4x4 with a shifter? I'm guessing it would be pretty hard to come up with something without replacing the whole drive unit.
Maybe mount the deck and snowblower to a GEO Tracker Did they make those in Diesel? - Seems there are a lot of diesel swaps - Or something similar in a diesel.
GEO Tracker diesel - Google Search
We were close to mounting a deck on the front of a 1982 Chevy Cavalier station wagon at one point. Just ran out of time
/ any toro groundsmaster fans on here? #470
If I go through another drive shaft, I may be very interested in making another drive shaft and doing something like this. I made my last drive shaft as opposed to ordering new.
I also made a safety hoop around the drive shaft. If it ever comes loose again, at least the drive shaft will not hurt anything else. The safety hoop on the 1998 325D was actually very easy to make and install. IIRC it only has 4 bolts. - One bolt to the frame on each side and 2 bolts for the hoop half.
/ any toro groundsmaster fans on here? #471
Depends on what cheap is. If it is close to $200 a ton, I would be all over it.
When I work on decks, I like to use as much stainless steel as possible - you can weld stainless with 7018, 8018, 9018 and many other rods and wires. You can weld stainless to mild and other steels. Even AR plate
I use a lot of anti seize and I use slick plate on the bottom of the decks. The slick plate really helps. The stainless also really helps keeping things from sticking or at least makes clean up much easier
/ any toro groundsmaster fans on here? #472
The service manual says there are two types of rear axles, the Insaka, and Dae Wong. This is why they have two types of clutches.
Service manual also says the reason for the over running clutch is during sharp turns the tail end swings out in a wider arc than the drive wheels. This causes the rear tires to turn faster than the front. I’m assuming this would cause binding and such on a full time 4wd set up.
/ any toro groundsmaster fans on here? #473
Thanks Aaron - I'll look at the Carlisle - that's the brand on the machine now 23 x 8.5 x 12nhs. I'll have to weigh the tires - but guessing 30-40lbs filled. Mileage will not be the issue, neither will puncture concerns. I think I might need new rims as these have some big dents and dings. The Cozy Cab is pretty heavy, but I'll be adding more weight to the back (steering) end because the weight of the thrower will bring the steering end wheels off the ground on a small incline.
Sorry for photo quality, but you can see I use double rubber tire chains - they work great on snow and ice. My GSD operator in training is at the wheel - hoping he can start doing the snow clearing this winter...
Could you get more pics of how your snowblower mounts?
Which snowblower do you have?
How does your shoot turn?
I have Toro 150 Accra industries Model 44910 I have never been able to find another to see how the chute was from the factory or exactly how it is supposed to mount to the machine.
I am in the process of making gauge/bogey wheels on the sides to keep it from sinking and scooping up the loose gravel in my drive
/ any toro groundsmaster fans on here? #474
My son works at a local golf course that owns two well worn Groundsmasters. One winter they actually disassembled one of the decks and formed metal from it to make another deck. They sheathed over their exiting decks with the new material. It still works to my knowledge. Both of these units have in excess of 6K hours on them and they currently use them as backup units.
/ any toro groundsmaster fans on here? #475
Cool thanks.
Yes, with the proper wheel offset.
Would something wider work? Not much wider with most of the mower decks. The rear deck wheels would hit the wider tire.
These are 23x10.5x12:
This shows the tight clearance with the Recycler deck. The rear wheels don't swivel like the side discharge deck does:
/ any toro groundsmaster fans on here? #476
Those look like they would work nice. Are you saying the 10.5” tires would hit the swivel wheels of a side discharge deck though?
/ any toro groundsmaster fans on here? #477
No, the side discharge deck has clearance:
/ any toro groundsmaster fans on here? #478
The model 30741 has a lever to shift to 4WD. I have seen one at a repair shop. Don't know any details of how it works. Found some pictures a long time ago:
And a snip from the parts viewer. I couldn't find the clutch that it operates:
And the optional full time 4WD driveshaft that clamps in place of the overrunning clutch:
/ any toro groundsmaster fans on here? #479
Thank you for clearing that up. Have you ever noticed your 4wd kicking in on a steep slope or loose Ground? I would imagine it is almost transparent to the operator when it does start to work.
I found a picture of that strange side discharge deck with the removable front lip. It is in fact a groundsmaster deck, the one in this pic appears to be a 60”.
/ any toro groundsmaster fans on here? #480
Yep, rarely noticed it kicking in. I removed the bent driveshaft on the 328D to straighten it and it wouldn't go places with 2WD, that it went in 4WD.
That is mounted on a Groundsmaster 72, the predecessor of the 300 series, so don't think it is 60" deck.
Those are slots on the front, to allow raising for tall stuff:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 INTERNATIONAL 4300 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2017 INTERNATIONAL...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
