Loader looking for loader
/ looking for loader #1
alflen52
Member
wayland,mi.
new holland 25s
anyone know of a somewhat reasonable priced new loader for a Kubota bx2200.so far it seems that they are all more expensive than loaders on new tractors.probably just wishing.
/ looking for loader #2
Koyoker(sp?) and Woods come to mind when looking at loaders that aren't made by Kubota. I'm not sure what you think one will cost but they aren't cheap.
yes,they are,what I have looked are those you mentioned and seem to be 4 to 5k range.was hoping to see one around 3k.but they may not exist.
/ looking for loader #4
I'm going by memory, and I may be off, but about 10 years ago when I added a loader to my BX, it was $3500 I think. Yours is a little unique in the fact that the joystick stays with the loader. It also might matter if your tractor is plumbed for a loader or not.
/ looking for loader #5
Sounds like it might be cheaper to trade for tractor with a loader?
/ looking for loader #6
I nearly doubled the cost of my used L2900 when adding an aftermarket loader painted orange with a bucket and a grapple - installed onsite... hasn't been delivered yet. Watching CL I could have found what I wanted and maybe saved a little on a bit better tractor, and had it sooner!
Edit: going on 4 months waiting for the loader - :confused3:
that does seem to be the way it is,luckily my tractor already has the loader valve on it.just looking for the future.tractor is great in every way even I bought it used.
/ looking for loader #8
I believe it. I priced a Woods loader for my older Kubota L2550. Found three Woods loaders are compatible from $6800 to $7400. I'd need the whole kit as my tractor is not setup for a loader. That's as much or more than my tractor is worth!
/ looking for loader #9
Hopefully adding it to your (my!) tractor will bring that value up. I'm very happy with the L2900. It was near perfect when I got it in May/June and now it's got a lot of scratches in the paint, a broken tail light and is looking "Used" after going through some brush clearing and pulling buckthorn's :thumbsup: That broken tail light will cost $260.00 or so from Messicks. :shocked:
/ looking for loader #10
New, or used, I would never buy a tractor without a loader.
It costs WAY TOO MUCH to retrofit a tractor loader, and it is never as good as a factory matched loader..
/ looking for loader #11
Messicks recently had a clearance sale, and one thing they listed was loaders for that sized Kubota.
/ looking for loader #12
Where were you before I knew about this forum?
/ looking for loader #14
I picked up a Koyker at the plant in South Dakota for $1500.00. It went on my Iseki TA247 ( Massey 1240 ) or ( Agco ST35 ). It's light but it's on a smaller tractor. I've worked it hard and have had no issues. Only down side was it came with a 2 valve control but there is an upcharge option for single.
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A62131)
UNUSED RAYTREE...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
