gravity feed Diesel tank
/ gravity feed Diesel tank #1
murph1
Ohio
MF-135 DK-40se Ventrac 4500
Hello all, I just bought a gravity fed diesel tank and need to change parts from barrel to nozzle. TSC has let me down on stock parts. Barrel is 1" out and would like to stay 1" through out. Any ideas guy's???
/ gravity feed Diesel tank #2
I don’t know what the question is but I have a gravity feed diesel tank that flows good. It’s all 1” and it’ll run 25 gallons in a couple minutes.
/ gravity feed Diesel tank #3
You should install an in-line filter however your flow rate will be greatly reduced with gravity feed.
Also an auto shutoff delivery nozzle will probably not work.
Other than that not much to say. One inch pipe fittings and hose.
Your outlet end of the tank should be a degree or two HIGHER than the back end.
/ gravity feed Diesel tank #4
Mine has an in-line filter. I couldn’t find any nozzles that work with low pressure so I built my own.
/ gravity feed Diesel tank #5
You’re smarter than me. Years ago when we had gravity tanks I would have a wooden wedge on hand to block the handle open.
Not the brightest thing to do if you have ADS.
/ gravity feed Diesel tank #6
Hello all, I just bought a gravity diesel system and need to change parts from the barrel to nozzle. TSC has let me down on stock parts. Barrel is 1" out and would like to stay 1" through out. Any ideas guy's???
Our local fuel Co-Op that delivers farm fuel has tank parts or can order them.
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
Dueling Tree (A65640)
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
2007 Cadillac SRX (A62679)
2007 Cadillac SRX...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
