DK 50 PTO problem
/ DK 50 PTO problem #1
LastSTRAW
Nova Scotia
Kioti DK 90, Kioti DK50SE with Cab, Ford 4610, Ford 2110, Ford 860, Hough Payloader, 1945 International Bull Dozer
I need suggestions on how to repair my PTO. It doesn't always turn on when l turn on the switch. I have ruled out a bad switch because with the switch on the tractor won't start. I have ruled out the relay because I changed it with the same relay for lights and both work. Hydraulic fluid is fine. Funny thing happened last couple of times. I slammed the cab door in anger and the PTO started. Once I get it started it stays running and will usually start again the same day without issue. The longer it sits the more likely it will not start from the switch. It runs fine once I can get it to start.
Very frustrating to drive to the field to Ted or rake hay and not know if the PTO will start. Sounds like something is gummed up or sticking. Any ideas?
/ DK 50 PTO problem #2
Have you tried cycling the PTO auto-manual switch?
The good news is it appears to be an electrical problem, not hydraulic.
/ DK 50 PTO problem
I did. Once working the switch works to shut off the PTO when I lift the 3 pt hitch but no effect on the start. I leave it in manual most of the time.
/ DK 50 PTO problem
Slamming the door works most times but not really an effective fix
/ DK 50 PTO problem
Update
Not fixed yet but the more I use it the better it works. This week I used it to mow and bale several fields. Only had it not start a couple of times. Door slam still working for now.
/ DK 50 PTO problem #6
I have a DK45SC, (which I know may be completely different than your DK50SE). Mine has two switches that operate the PTO, a switch on the dash which turns the PTO on/off/auto, and another switch on the (right) door post which is a push on / push off switch. I used to keep the dash switch on (or auto), and use the door post switch to turn the PTO on/off. A few years ago, the door post switch started becoming "problematic", and (being as lazy as I am), I just found the "sweet spot" on the door switch; leaving it on always, and using the dash switch instead - I will get around to replacing the bad switch "one of these days" (probably when it completely gives up).
When the switch started acting up, it was obvious what was happening, so I am quite sure it is not likely the same problem your having. Still, the door post switch being "on" will not prevent my tractor from starting (the dash switch must be "off"), and (being on the door post), it might be very "amicable" to a (good, hard) door slam vibrating it into contact (I've never tried it)
Anyway, I wish you the best of luck in hunting down your gremlin!
/ DK 50 PTO problem #7
I have the same problem with my DK 40 se for some time now. Usually if i hit a bump or drop 3 point hitch quickly it starts but today it will not turn on at all. I did notice that the pto switch will not light up but if i turn off 4x4 the lights come on pto switch. Also when i turn on PTO the 4x4 dash light comes on.
/ DK 50 PTO problem #8
I have this problem (and have had it) for several years. It always seems to work okay when I have a mechanic looking at it, and it seems to definitely be tied to moisture or non-use. The dealer said it might be a relay under the floor of the tractor, but I've just gotten used to putting the tractor out to "Catch the Rays" on the right side of the tractor, or driving it for 20-30 minutes. It is a PIA, but not enough for me to really track it down...
/ DK 50 PTO problem #9
I spend many hours yesterday and today checking connection and looking for a loose wire with no luck. I then decided to take the tractor down over a steep hill to see if the 4x4 was working as PTO and 4X4 are on same fuse. Turned out the 4x4 doesn't work along with the pto even though the 4x4 was lite up. I then came back to garage and by mistake took the bottom screw out of the fuse box thinking it was holding the cover on bottom. I put screw back in check fuses and there still all good. Started tractor and PTO and 4x4 are working.. So I am guessing the bottom screw was not making a good ground. Will keep you posted if the problem comes back.
/ DK 50 PTO problem #10
Maybe a bit too much salt air up there in Nova Scotia.
/ DK 50 PTO problem #12
Mine is not a Kioti but I have to raise and lower the 3 pt hitch before my pto will turn on, or at least raise it if down, if all the way up have to lower and then raise.
/ DK 50 PTO problem #13
Maybe your right Jim..lol not working again and I can't find the problem
I think you have a very bad connection somewhere or a bad wire. Time to start wiggling things with the PTO switch in the on position to see if you can get it to either work or get it to go off.
/ DK 50 PTO problem #14
I have trace all the wires and connections. took connections apart and they are all clean and tight. I even had a mechanic from the dealer come out and still can;t find the problem.
/ DK 50 PTO problem #15
The only real solution is to take a test light and start checking everything in the entire circuit to find out where the short is or the bad switch. I would start at the PTO switch to see if you have power there. From there move on to the next connector.
/ DK 50 PTO problem #16
A couple of years ago, I had a dealer loaner DK50 for part of the winter. My DK45 is cabbed, but the DK50 wasn't; also, it spent its life outdoors. The PTO relay switch didn't want to stay engaged; the PTO ran as long as I kept the button pushed down, but stopped as soon as I let go. This doesn't sound like its the source of your problem, but thought I'd mention it.
/ DK 50 PTO problem
Problem finally found. After many hours my mechanic found a short in a module behind the steering wheel that wasn't on the wiring diagram. 10 hours of raking hay since he returned it and it works every time.
/ DK 50 PTO problem #18
Awesome
/ DK 50 PTO problem #19
Shat module? There should only be a 2 pole relay and the switch. Weird
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2015 Nissan Sentra Sedan (A61574)
2015 Nissan Sentra...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2010 Dodge Charger Sedan (A61574)
2010 Dodge Charger...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
