My loader on my 3020 doesn't work
/ My loader on my 3020 doesn't work #1
dvaidm
Member
Harding mn
3020 john deere and 50 john deere
My loader and my 3020 doesn't work I added fluid but it still doesn't go up or down or can't tilt the bucket either?
/ My loader on my 3020 doesn't work #2
My first bit of advice is to look at what is 'common' regarding the symptoms.
If the FEL will not raise/lower AND tilt up/down, then the common fault location is in or around the operation of the joystick. It's not engaging either of the hydraulic blocks.
Failing that, the next common fault location is the supply of hydraulic fluid/pressure to the block that is operated by the joystick.
Figured it out somehow someone or somehow where the hoses plug into the back they close the valve so there wasn't no flow fluid but thanks it works now
/ My loader on my 3020 doesn't work #4
Good stuff. Thanks for reporting back with the fault/solution. :thumbsup:
