Best Attachment for Grading Gravel Driveway
   / Best Attachment for Grading Gravel Driveway #21
In this case the rear blade is best and like I mentioned earlier the most versatile implement for road work, but also probably the hardest to really master. You can order a variety of them with skids or rear gauge wheels that will really help it stay at a more level plane with grading. You can also get side plates with most to make the move material similar to a box blade.
What size tractor are you using? I might have overlooked that.Here is my Land Pride RBT4096 pulling ditches on our drive.
Thanks! An L6060 (no cab), 62 hp. Decided to get 3 remotes...all valves are double acting with float detent option, and TNT. All Kubota installed.
   / Best Attachment for Grading Gravel Driveway #22
I guess I'm talking about a land pride type hootus, not a blade/box blade, not a harrow; digs rocks/finds up and they pass over an angled bar and fall. Saw one in action and if I had the need for that service, it would be the implement without question.
   / Best Attachment for Grading Gravel Driveway #23
I use a 6' landscape rake.
Another vote for the landscape rake. I use a 5 footer with gauge wheels to maintain our crushed concrete road.
Cover that gravel with good quality crushed concrete and you won't go back.
   / Best Attachment for Grading Gravel Driveway #24
You have a pretty road, but not much of a crown from what I can see in this one photo. I'm not being critical...it just seems pretty flat/level straight across. Nothing wrong with that if that's the way you like it...except water will lay in the road instead of running off. Our house site is up a mountain, so we need a better crown to keep water running off the road instead of down the road. A really good crown solves most maintenance issues, especially with a solid rock base.
I do like my road the way it is - thank you. After all the main purpose of maintenance is to shape it so the water runs off w/o erosion and doesn't pool on the road. In my thinking there are a lot of good reasons why not to have a crown. As you noticed some parts of my road are flat - but they are not level. They are canted to one side so all the water goes to the down hill side. They are usually on a portion that is fairly level or w/o much grade change and the up hill side ditch is minimal because of ledge. Other places I have a normal crown. Especially on hills where you need to shed the water faster. I don't normally get those pot holes from pooled water except right after the winter thaw and mud season which is a northern thing you may not be familiar with.
gg
   / Best Attachment for Grading Gravel Driveway #25
That road looks perfect Gordon! I can see your crown better in this pic too. Very nicely done sides too....good drainage, not too steep, no wash outs, no ditches, can mow it. Well done!
   / Best Attachment for Grading Gravel Driveway #26
There are many variables on which driveway and tools are best. The amount of moisture and temperatures, the type and amount of the traffic, the speed of that traffic, drainage ability of the road material and surrounding subsoil, amount of runoff, available gravel types, elevation and grade to name a few. All a person can do is try to pick a situation that closely matches their own and use those suggestions.
   / Best Attachment for Grading Gravel Driveway #27
Master of the obvious...
   / Best Attachment for Grading Gravel Driveway #28
LoL...if there were such a thing most of the threads on TBN would only be a few replies long...i.e., there would be no need for 20+ replies about an old grade school math riddle that the only riddle is in the verbiage...:D
   / Best Attachment for Grading Gravel Driveway #29
Concrete truck and 4 assistants. 14.6 full loads. 4" thick x 11' wide. Priceless.
   / Best Attachment for Grading Gravel Driveway #30
How many cubic yards in those trucks?
Like many here, I'd rather have a gravel driveway. Not everyone likes concrete. And these days, gravel is often considered an upgrade to concrete, especially in high end homes. View attachment 572951iu.jpg On really long driveways like you find on many farms here, using concrete would just be silly, not priceless.
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
1999 NUTTALL FOUR AXLE TRAILER (A58214)
1999 NUTTALL FOUR...
