Is it a 2000 or 3000
   / Is it a 2000 or 3000 #11
I am fairly certain this is a Ford Dexta. I can't locate a source for decoding the model though.
   / Is it a 2000 or 3000 #12
It is a Ford 2000 or 3000. A144-336 is the serial number (A for Antwerp, Belgium), normally, the Model Number should be stamped nearby it. This does not seem to be the case here. British and US made tractors had a sticker on the underside of the hood, over the battery, with the numbers on it. Antwerp made tractors may have that (though I can not see one on the picture), but instead there may be a metal plate riveted somewhere. I have only seen the plate close up on pictures, but I guess it would be placed on the firewall or on the inside of the hood.
Edit
I tried to understand some discussions in Belgian/French forums, and it seems that some owners found the plate on the wall in front of the radiator, see arrow in attached picture. Perhaps it could be on the other (front) side of the wall, or the fan shroud.
An easy way to find out if it is a 2000 or 3000 is to look for the spring for the draft control. I can not determine from the pictures, but if you can see a fat spring behind the driver's seat, then it is a 2000. 3000 had a cover over the spring.
Here you can see the spring on a 2000:
Lot 34 Ford 2 Tractor Lift Operating - YouTube
   / Is it a 2000 or 3000 #14
It is a Ford 2000 in the video, probably a British video.
Fordson tractors were made at the Dagenham plant in Great Britain. At the end of production the models were Dexta, Super Dexta, Petrol Dexta (not many of those were made) and (New Performance) Super Major.
Fordson tractors were very popular in Europe, especially in Great Britain. When the "World Series" 1000-series came in 1965, Ford decided to keep the Fordson model names, together with the new model names on brochures and hood decals on units made in Great Britain, during the first years of the 1000-series. The idea was to make the customers see the new models as enhanced versions of the popular Fordsons. In fact they have nothing in common.
Here you can see the decals:
Histoparts
4000 got Major as a supplement, Major was an earlier Fordson model.
So, the 2000 got Dexta as a supplement, but it has nothing to do with Fordson Dexta. The name still lives on in Great Britain and other parts of Europe.
   / Is it a 2000 or 3000 #15
Could it be that the Ford 1000 series tractors made in Great Britain and branded with the old Fordson names as you explained have their own model code format?
   / Is it a 2000 or 3000 #16
No, it was just a sticker gimmick.
   / Is it a 2000 or 3000 #17
Here痴 a side view. I can get a better pic over the weekend
I think 2000 should work since the current 2000 label looks old and it does not have power steering which proves nothing. On a 50+ year old tractor I think old decals are more likely correct. I mean like what farmer or dealer would remove 3000 decals and replace them with 2000 30 years ago?
   / Is it a 2000 or 3000 #18
You could turn that the other way around.
Say it is a 3000 and the hood panel was damaged during the 50+ years and a replacement from a 2000 was used. What farmer would take the time and cost to put the correct decals on it?
   / Is it a 2000 or 3000 #19
Now I see what you mean...
It is the 6L15C and 6L16? Those are date codes.
6L15C means that the transmission was built November 15th, 1966
6L16 means that the tractor was assembled November 16th, 1966
C means Afternoon shift, shift code omitted for the tractor unit.
Look here:
FORD CODES and SERIAL NUMBERS
I can’t find a model number anywhere on this tractor. Here is some more data I’ve found.
Stamped on opposite side from where the serial number is C7008. Manifold stamp is C5NE-9425-k below that is SM
Welcome to the Ranch Decorative Sign (A55853)
Welcome to the...
TANK MANIFOLD (A55745)
CATERPILLAR T30D WAREHOUSE FORKLIFT (A52707)
CATERPILLAR T30D...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
CAT 416B (A47477)
CAT 416B (A47477)
