plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,087
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I want to create a level RV parking pad. The area has a slight side slope from right to left, and a slight upslope as you pull forward. I need to level both of those. I have a 40hp tractor, 6 foot box blade, landscape rake, and top n tilt.
I started by tipping the right side of the box down, then lowering the box and slowly moving forward. It cut into the side slope as expected. But it is not moving the dirt from right to left as much as expected-- either that are I am too impatient? Also, I only worked in one direction, back to forth, which I think might be a mistake.
Questions-
1. If I can get the box blade to equally tilt in either direction, should I be working this pad in both directions?
2. Should I cut the high side all the way down to grade level first, or instead alternate working the "high side to the middle" and then the "middle to the low side."
Any help would be appreciated. I've never done this before. Scraping only a small amount of dirt, I've already exposed many football sized rocks (a surprise for my area,) dredged up the base of a broken glass bottle that could have punctured a tire, and torn into a submerged old 1" galvanized pipe. (I think that was the original water supply for the residence which has been abandoned.)
Questions-
