How to use Box Blade on a side slope?
   / How to use Box Blade on a side slope? #11
The best way to get anything done with a box blade is to disconnect it from your tractor and put it somewhere where it can be useful storing real tools.
Use your front bucket to build the pad. After dumping the dirt, back drag it to get it flat and level.
If you can't find somebody to buy the box blade from you, trade it for something that's useful. Or just give it away!!!
   / How to use Box Blade on a side slope? #12
I've found my best results for this to come from the side with my loader/perpendicular approach with the tractor and loader at first (I have a tooth bar and it helps). I cut the path to the level I want from the side approach until I have that level for a long enough spot that my tractor can then come at it from the parallel direction. Coming then straight on, I can maintain that same level or slight slope that I fabricated from the side and since my wheels are all on that trajectory, the loader then bites into the hillside maintaining that same angle the entire length I am trying to go. I move the dirt I pull off the high side to the down hill side and dump it and smooth it on the low side as I go so I continue on the exact same slope with my wheels from the original path I wanted to take.
Once all the roughing in that I call that is done, I then use the box blade for final touch up and smoothing out of the grade. Then only small adjustments need to be made.
If doing like you're starting out, I'd drop the rippers so you actually loosen up more right from the start, then as you get closer to the desired grade, I'd raise the rippers and make the minor adjustments.
I just find that by doing it the way I stated first, I am looking forward most of the time in developing the slope I'm attempting and I can move a little sideways here and there and back drag with the loader as I go to keep the rough slope I'm after without wearing out my neck. Then the box blade puts the final perfecting finishes after all is packed out where I need it.
   / How to use Box Blade on a side slope? #13
When I bought my tractor I bought a rear 72" grader blade used for $100 and bought a new Titan 60" box blade. I had read on here about the box blade really being a great tool. I have used it a few times to rip up and fill in rain grooves on my logging roads, but that it about all I found it really useful for. The rear blade is a lot more versatile and useful. The box blade is by far the least touched attachment that I have, I really should have bought a rusty old used on instead of dropping $600 on a new one to leave it set in the tree line to rust. Or I should have not bought it at all. If I have a person stand on the rear blade it will dig just as hard as the box blade.
To the OP, I would start out with the loader and get yourself started, you'll spend less time that way.
I have a flip down blade on my York landscape rake. Have not used it yet either, but I see I'm going to need to try it out.
   / How to use Box Blade on a side slope? #15
I actually find my box blade to be a good tool, but laughed at what Eddie and Rock Crawler had to say.
I use if for the finishing touches and have used it very successfully on smaller dirt jobs where I only had to pull a small amount of grade from high side to low side, but I also use it regularly to maintain our gravel road and it does a tremendous job with that work.
I also leave it on very often for the extra ballast to get the most work out of my loader. I'd rather have it than a ballast box anyday. Way more useful. Also, if the soil isn't too rocky or filled with roots, I can gingerly back up with the box blade and get a really nice initial cut in some areas that may be harder to get to with the loader. It has it's uses for me.
That said, my grapple is my favorite attachment by a long shot.
   / How to use Box Blade on a side slope? #16
To address the OP's questions:
Questions-
1. If I can get the box blade to equally tilt in either direction, should I be working this pad in both directions?
Yes--that will help with the dirt pile at the end. I tactic I have used in the past is on the return trip, to work the dirt at an angle to the main direction of grading.
2. Should I cut the high side all the way down to grade level first, or instead alternate working the "high side to the middle" and then the "middle to the low side."
I have generally started at the top and worked my way down leveling across as I go....not quick, but effective.
As Eddie and others mention, you may be better offer doing this with different equipment.
I have done work like with with BB, but it is slow going.
Good luck.
   / How to use Box Blade on a side slope? #17
Also, a 6 way blade attachment is much cheaper than a dozer. :)
A person does not have to purchase a dozer, or worse yet, rent one if they have never operated a dozer before. Sometimes it is more efficient to hire a job done. Although depending upon the size of the job, the biggest part of the cost is for hauling the machine to and from the site of the project.
Box blade verses rear blade, each has the specialized purpose and can compliment each other. I have never had one or the other just sitting around forever rusting away. :rolleyes:
I believe the O.P. has gotten some useful info on how to proceed with both and also using a backhoe and bucket loader to get his job done. Just take it slow and easy to start off. It's not a race to the finish.
   / How to use Box Blade on a side slope? #18
A box blade isn’t a dozer and you’re going to be disappointed if that’s what you want. I find my box blade quite useful. It’s much better than the FEL for some jobs. Even if it’s doing nothing it’s still good ballast.
   / How to use Box Blade on a side slope? #19
I try to keep in mind what a box blade is best at. Moving material from one location to another and spreading material.
A box blade is difficult to shape with. And it will not move material left or right.
For your project, using only a BB and FEL, I would do as "girl who wants tractor " says.
Rippers down, tilt forward some, tractor facing downhill, drop the blade and drag the material down and drop into the low side.
You can also go across the hill like you are now but once the box has collected all it can, turn downhill and raise the blade dropping your material.
Go to where you turned off and continue across, repeating.
Once you have piles of loose material around, tilt the blade rear ward some and spread it out. Packing and smoothing.
Once the material is loose, you can also use the FEL to move some around, and use the FEL to back drag and smooth.
Keep working it until it is how you want it.
   / How to use Box Blade on a side slope? #20
I agree with this. A BB excels at three things: driveway maintenance, trail maintenance, and ballast. By far, IMO the thing it is best at is trail maintenance. Adjusted correctly, you drive along and leave a nice smooth trail behind you and the BB also picks up most of the rocks and sticks. I can't imagine wasting money on mere ballast. At least with the BB, as you're working along and suddenly see something that needs to be smoothed out, you have an actual implement mounted instead of a hunk of concrete. That being said, I also find the front implements (like a grapple, FEL, or pallet forks) to be the most versatile, I think because they are so much easier to control precisely--without hurting your neck by looking behind you.
Yes, a heavy BB can also DIG.
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
(APPROX 10 PCS) 2" X 6" UP TO 10" TUBING (A54756)
(APPROX 10 PCS) 2"...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
