shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,370
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Oddly, when all I had was my garden tractor pulling a lightweight 36" little Brinly box blade, it was actually easier to do the smoothing out, as I could set it to float and skim along the dips and bumps. OTOH, it lacked power/weight so to change the grade at all required about a million passes.
All the videos you see of people cruising along merrily box-blading a drive are on a level driveway! Yeah, "level" is easy.![]()
EXACTLY!!
When the dips are 20-30 apart I doubt even a land plane will level a driveway unless we take take dozens and dozens of passes. I have considered adding 8 2x6痴 skids to a box blade to increase the length. My little pea brain looks at the old hand jointer planes used to prepare wood. Longer was always better. There is a reason road graders are so long.
I know the 2x6痴 would not last long, but they are cheap. And once the drive is level, they would not be needed again.
MVR made a good point IF the land plane will work, that is a better option. And I assume it will not need a hydraulic top link to get the job done....saving another few hundred $$$. Sorry for the thread hijack. I may start another thread on this issue.
