B2650 ROPS light mounting bracket?
/ B2650 ROPS light mounting bracket? #1
Rob 80
WVA
B2650
Did a search there a lot of post about adding lights to a B2650. I'm looking for some type of mount so i do not have to drill into my ROPS, i don't have any scrap laying around or anything to use.
These are the lights i was going to buy. With a light bar i don't know how much you can aim it that is why i picked these.
Amazon.com: SHANREN 27W Round LED Work Light Lamp Off Road High Power ATV Jeep 4x4 Tractor 3 Degree Spot Light: Automotive
BTW is it worth upgrading the stock head lights to LED? to get more light...
Been toying with the idea of side lights to but one thing at a time.
/ B2650 ROPS light mounting bracket? #2
I use a large metal 'hose clamp' (as many as required) to attach/hang objects from my ROPS. So far it's a fire extinguisher off of the right side and an LED light-bar from underneath the center of the ROPS. They screw on just fine and have held up for years.
I also use old cut-up, foam neoprene "stubby holder"s (koozie?) between the clamp and the ROPS as an anti-vibration layer and to protect the ROPS from metal-on-metal chafing = rust forming.
/ B2650 ROPS light mounting bracket? #3
what I used for mounting lights were square u bolts. picked them up at local hardware store, like 3 bucks each zinc plated. I'll send pics tomorrow. You can also buy the stock ones from kubota I think they are 8 bucks or something like that each (check the parts listing for the grass catcher -- they are part of the hazard lamps.) The kubota ones are incredibly heavy duty, probably more than is needed. I bought Nilight lights from amazon. Very bright, so far so good. If you have a loader, headlights are nearly useless as the bucket will block the lights as you are driving around.
Do you know the part # for the kubota ones? I never thought of u bolts wouldn't you need a plate to mount to?
/ B2650 ROPS light mounting bracket? #5
I used studs that attach with epoxy. They're used in the aircraft industry. You have to sand the paint off where you want the studs, but my ROPS needed touched up anyway, so I repainted it. :: Click Bond, Inc. :: Studs & Standoffs
I can't remember if I got the idea from this site?
/ B2650 ROPS light mounting bracket? #6
The Kubota supplied work light uses a formed steel bracket with a hole to mount the lamp, which has a vertical mounting stud. The bracket is clamped to the ROPS with square "U" bolts. I have them on my B3350 and L6060.
SDT
/ B2650 ROPS light mounting bracket? #7
I think I may have noted this somewhere, I'll look for it and post back here.
/ B2650 ROPS light mounting bracket? #8
Here are some pictures of my setup. Hope this helps. First, I got a waterproof switch, and used silicone sealant to affix it to the dash so water can't get in behind it. Its wired direct to the battery so I can turn the lights on when the tractor isn't running, which is convenient.
I have two 4 inch floods facing rear. These square u-bolts were fairly long. I put nylon spacers to keep tension and give me a little space to work with then cut the extra bolt threads off with a hacksaw. The lights come with the little bracket, just put it on over the end of the bolt and tighten it up. Holds great.
/ B2650 ROPS light mounting bracket? #9
Front facing I have a 12 inch combination spot/flood light bar. Same setup as with the floods, one bracket each side.
/ B2650 ROPS light mounting bracket? #10
/ B2650 ROPS light mounting bracket? #11
Here is the part information for the kubota oem mount that they use for the hazard lamp. This is thing is beefy, perhaps overkill but whatever. They have separate part numbers for the pieces that make up the assembly. Here goes:
The backing plate: K2581-96270
The u-bolt: K3181-62243
The nut that holds the u-bolt on: 02751-50080
Here is a pic of the hazard lamp mount.
/ B2650 ROPS light mounting bracket? #12
I went to Tractor Supply and got the square U-Bolts that fit the ROPS bar, I cut out and drilled my own back strap similar to what you see in the post above showing the Kubota ones, then I made a bracket to attach to that U-Bolt that would fit my 3 NiLight LED cubes per side. This way, I hit my switch and get a 360ー halo of light. I have spots in front, spots facing rear and floods on the sides.
The only 2 negatives I have found is that:
1) I can easily rip the lights from the brackets, I can shear the brackets and/or I can tear the aluminum light housing from the nut that the bracket bolt goes in to. All it takes is a solid tree and you can quickly clean the lights off..... I've had to hoopty-rig them back together many times now.
2) You must use medium Loc-Tite thread locker on all of the light fasteners. They will rattle loose and the lights become hanging clankers! After seeing this happen a few times I took an hour and in-bolted every fastener and thread locked them, now at least the lights stay on there until a tree cleans them off!
I have been running NiLight LED cubes on my Jeep and SxS for 5 years now. It is the only brand I buy because they offer exceptional value with a very fair price and unbeatable reliability/durability.
Amazon.com: Nilight 2PCS 18W 126lm Spot Driving Fog Light Off Road Led Lights Bar Mounting Bracket for SUV Boat 4" Jeep Lamp,2 years Warranty: Automotive
/ B2650 ROPS light mounting bracket? #13
That is really an innovative way to deal with these kinds of issues. Thanks for the post (an idea which can probably be used for a lot of other purposes too.)
/ B2650 ROPS light mounting bracket? #14
You have hit upon a universal problem that many/most of us came across. RockCrawler, Atticus and SDT all gave you good descriptions/pictures. I will add to the chorus as follows:
I used a square U-bolt (as I think most do) selected to fit the larger dimension of the ROPS frame. No reason to go flimsy, use a heavy one. I replaced the flat cross part of the U-bolt with an aluminum bar maybe 1" wide and 1/4" thick. That is of course very easy to cut with common tools/hack saw, to drill, etc. I made the cross piece about 2 to 3 inches longer than the original cross member and drilled it to fit the U-bolt which makes a very solid mount. Then drill the outer end of the crossbar for the lights. I mounted two lights, one aimed forward and one aimed to the back. This makes a pretty universal approach, can be mounted on the side of the ROPS, the top underside, the top on the top side of the ROPS, etc. Use lock nuts/washers of course. I found the light swivels (made as part of the lights) are harder to keep pointed in the same direction without vibration, branches, etc. changing them.
That was easy. The greater challenge to make a halfway neat job of it is the electrical part. The wires can be weather resistant twin cable of some sort that looks nice with the usual zip ties to secure to the ROPS on the way down. I too went to a direct accessory connector to the battery with a pair of toggle switches just behind the driver's seat and an in-line fuse.
On a different B2150 than the one shown below, I rummaged around until I found a spare circuit with a dangling unused wire near the rear of the tractor. Tested it with a meter to see which switch turned it on, etc.[most likely it was originally for a rear work light...] and used that for the electrical source. Who knows what the circuit was intended for (comes on when the headlights are on) and it blew no fuses so I am happy. That avoided adding any switches or fuses. These were done years ago prior to the better LED lights we see these days.
/ B2650 ROPS light mounting bracket? #15
Here is my solution. Sorry, not a great picture. I used rectangular tube, cut on a diagonal, attached with square U bolts. The lights are protected from low limbs, as they just fold back supported by the tubesIMG_0718.JPG
/ B2650 ROPS light mounting bracket? #16
As an aside, would you please describe for the audience what that thing is that looks like a 5" wide 40 lb home made machete ?
/ B2650 ROPS light mounting bracket? #17
Ha ha ha yeah I was wondering the exact same thing!
/ B2650 ROPS light mounting bracket? #18
Attached to the rops? If that’s what you mean, it’s a wooden scabbard for a chainsaw, bolted ( or strapped) to the upright. Of course, there’s no chainsaw in it, but the saw slides in. I was too cheap to buy a pre-made scabbard, so I made one.
I'm surprised that there is no aftermarket product light kit for tractors. Now i need to find some decent wire any idea on what gauge?
thanks for the help everyone and for the part # atitus74
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
2016 FORD EXPLORER SUV (A67737)
2016 FORD EXPLORER...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
