Does anyone know what the timing marks look like for 3038 injection pump gears?
   / Does anyone know what the timing marks look like for 3038 injection pump gears? #11
That's a VE pump.. Your GONNA HAVE TO ANSWER the questions..Was the pump REMOVED FROM THE GEAR?? Was it KEYED??
Did you MOVE/REMOVE THE GEARS from one another??
Does it have a LIFT PUMP?? Have u checked the INLET PRESSURE??
Have you MOVED THE PUMP left & right & checked the response??
Pump not removed from gear, comes out with gear still attached.
Doesn’t have lift pump
Haven’t checked inlet pressure but do have fuel flow by gravity
Moved pump left and right but couldn’t tell if much of response bc engine would just continue to slow and die
   / Does anyone know what the timing marks look like for 3038 injection pump gears? #13
It "sounds like" a fuel supply problem?? Follow the fuel lines to MAKE SURE it doesn't have a lift pump..
WHY was the pump removed??
The 7's are clearly marked.. If you look closely, there are what look like 7's next to the 6's on the pump gear.. Your 1 tooth off..
Pump removed to repair fuel shutoff solenoid. No lift pump.
The drive gear has two 7’s, the pump gear has two 6’s and two V’s. That is where I’m confused. Shouldn’t the pump gear have just one 6 or V so it will line up in middle of the two 7’s on drive gear?
I will check further on fuel starvation problem and report back, maybe there is air in system
   / Does anyone know what the timing marks look like for 3038 injection pump gears? #15
Cant tell if they're "V"'s or "7"'s..
Why in thehell didn't u mark the gears?? Have u spun the engine all the way around to see if there are any other #'s??
I've changed THOUSANDS of solenoids with out removing a pump. Grind down a 15/16 wrench.. I know its metric.. but "I've" never had to take 1 off.. just sayin..
When taking cover off, pump dropped and disengaged drive gear before I could mark it, I think it’s only a tooth off but I have never removed a pump that wasn’t marked clearly with dots, dashes, etc. I’m not a jack leg mechanic, just not expert on LS tractors. That’s why I’m reaching out for advice. Tried to remove solenoid but it was too tight to work on without removing pump.
Update, got timing figured out. Now issue is it dies when low idle after running for minute or two. Like starving for fuel. Blew out lines to tank and to pump and fuel is getting to it. Since I took injection pump off, could there be air in injection lines or pump and if so, how do u purge it?
   / Does anyone know what the timing marks look like for 3038 injection pump gears? #18
bleed the air out by loosening the lines at the injectors. turn over until all air bubbles stops bubbling and only fuel coming out. Usually one will clear up then the next. Once all lines are pumping only fuel the tighten em back up and fire it up
   / Does anyone know what the timing marks look like for 3038 injection pump gears? #19
^^^ what Gimmodog said.. ^^^
Have u pulled & had the injectors checked??
Sorry about the stupid questions.. BUT
The quality of your questions dictate the quality of your answers..!!!
JUST LIKE ABOVE.. "got timing figured out">> well what was it??
U might not be a "jack leg" but your very hard to communicate with..
Haven’t pulled injectors yet, haven’t been an issue until now.
I did bleed lines like you guys suggested and still dies eventually.
I will describe what it is doing now to the best of my ability. It will crank and slowly catch or fire up when cold. Will go to full power without problem, then I lower to say 30% power and it starts to lag or start slowing on it’s own, I’ll increase throttle and it does nothing. Then it continues to slow until it dies. Hard to start it back after that unless I wait for say 10 mins.
I haven’t done anything to pump except repair solenoid shut off valve. Simply removed it from tractor and replaced it, I did mark timing marks, the adjustable external adjustment, and had hard time finding timing gear marks but finally figured out the numerous markings on pump/drive gears.
Replaced fuel filter, blew out fuel lines, added fresh fuel. I’m at a loss for what to do other than taking pump and injectors to diesel shop?
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
