155d injector cleaning
/ 155d injector cleaning #22
...While testing 1st, they ALL opened at the exact same pressure{low} but 2 of the 3 had REAL BAD spray patterns & wouldn't chatter. I replaced ALL 3 nozzles & they worked flawlessly.
What is typical hours before injectors become this worn out?
And, what is your experience with biodiesel? Same service hours before injector overhaul? More corrosion? Any other difference?
/ 155d injector cleaning #23
I might get raked over the coals for this but its the truth, however hard it is to swallow.. Straight Bio fuel is killing your fuel system.. "IF" left to sit for any extended period of time.. It'll gum-up a system in 2-3 weeks if left stationary w/o any additive.
I don't care what u say or what YOUR experience is.. its the truth..
ANY additive in Bio fuel is better than no additive.. PERIOD.
Now if you fill your tank & run it.. it works just fine.. just don't let it SIT.. PERIOD.
Chevy>> in your 1st post u stated you've rebuilt LOTS of injectors..but you keep asking questions like someone from another planet, who doesn't know what a diesel engine is..??
Take 1 apart..get the noz. # & google it..
Hey man. I was trying to simply gather info before tearing it down. All my experience is/has been with Deere and Cummins and Isuzu injectors. My pride does not keep me from asking questions about something I've never been in. I'm sure it's no big deal but was just trying to keep the down to a minimum. Apparently asking questions is a no no. My bad......
/ 155d injector cleaning #28
That's a real fair price for the nozzles..
U ordered a new complete injector?? JUST 1??
Yes the other was fine. No real reason to replace the other in my opinion. Pattern was fine, and has less than 200 hrs on it
I would normally be putting all new in but, this being my own tractor I'm ok with not. Plus I now know the injectors both come right out easily
If this wee a customer, I'd be suggesting both. But it's not so I'll do the one that's bad and leave the good one alone
/ 155d injector cleaning #32
I'm confused.. did u order a new COMPLETE INJECTOR or just get a tip??
& the decision of just getting 1 is a bad 1.. the opening pressure is going to be different..
Hoye has the tips for 30.00.. shoulda just ordered 2 tips & been done.. but hey its your machine..
Good luck w/ the repair..
Thanks for your input. I ordered a complete one. I do agree with always doing two for the pressure reasons. I am planning on setting the used one to what the new one is. As stated before, ONLY reason I am doing this is because it's my machine and I aware of what I'm getting into.
Little update on this thing. Installed new injector, and still had no fuel coming out of the Injector. Had what seemed to be the same amount and pressure as #1. After removing the delivery valve holder on the pump, I found #2 did NOT have the delivery valve spring in it. Lol. This tractor only has 300 he on it and looks **** near New. I know the original owner and I am now the 2nd owner. He said this thing always started hard and seemed like it was low on power. I am now wondering if it somehow slipped through the cracks like this from the factory. I don't know. I'm trying to locate all the parts for #2 injection and I'll see if it works. Was going to swap parts from the other but didn't want to mismatch machined items. But I'd say I found why the injector wasn't making any pressure.
/ 155d injector cleaning #36
Do u have the pump out?? IF NOT & u took the holder out, the barrel probably came off its seat..
& u have to be very very careful reassembling it.. The barrel is centered in the housing w/ a lead pin..
If the barrel is off its pin & you torque the holder back down.. it shears the pin & your S O L..
THERES A REASON people do this for a living..
The pump is not off the tractor either.
I guess all of us who don't work on these every single day are not worthy, to your standards at least. This will be more than likely the last post I do on this thread. Just kinda tired of the "worthy than tho" crap.
/ 155d injector cleaning #39
Its not like THAT.. I'm mearly saying your over your head.. Your taking things apart and your making it worse..
If you get a spring & go to tighten it up.. your gonna shear the pin the housing.. but seeing you've done abunch of these.. go right ahead..
How about YOU keep posting & "I" wont comment..
I "thought" I was helping..
That's kinda funny then. Why does it now run perfectly? New DV's and springs and it runs like a brand new tractor.
For the record, I stated I've done alot of Deere, Cummins, Isuzu injectors. Not claiming to be a know it all. The day I become to proud to learn, is the day I should hang it up. I'm know I'm not over my head here, this style governor and fuel pump and injectors are pretty simple. But hey what do I know. It's not like I've been working on heavy equipment for 15+ years and fully certified as a Deere field technician or anything.
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
