Kubota B6100E
/ Kubota B6100E
Hello 1930 - I used to have a Kubota B6100DT about the same vintage as yours. Your pictures look very familiar.
To answer your question about getting a "genuine" set up for the draw-bar, there is no such thing as far as I know. A draw bar is an "attachment" and so any manufacturer's attachments that are CAT1 (That's basically a size specification) will fit and work on your B6100E. There is no reason go get Kubota attachments. You can get drawbars and other attachments at places like Tractor Supply, you local tractor dealer or on line.
As to specific parts for your tractor (filters, switches, etc) check out Messicks on line: Kubota B61 Parts
As to the glow plug - my light came on as soon as I put the switch in the pre-heat position - which I held for max 30 seconds in winter - maybe 10 seconds otherwise. My oil pressure light came on within seconds of engine start. As I recall there was a warning in the manual that said if it doesn't come on in 5 seconds after start - shut the engine down.
Thanks for the link, Im gonna get some stuff.
/ Kubota B6100E #22
This should be Your Fixed Drawbar, note it is Not a 3Point category 1 attachment.
/ Kubota B6100E #23
This is what I have at this point, a well used place to attach a fixed drawbar.
Can you suggest one that will fit properly no doubt about it or do I need to take some measurements?
Ill need hardware as well.
Looks like the reciever is there, the rectangular box just under the PTO... There is nothing too special about it, Measure the height & width so you know the size that will fit into that box... also measure the hole size for the pin that will pin it in place.
I would take those measurements to a tractor salvage and see if I could find a used one that would fit. Ideally it should be long enough to put the ball mounting hole 14 inches behind the tip of the PTO shaft. but that is not going to be a critical measurement for towing a trailer... KennyV
/ Kubota B6100E
14 in behind that's good information thanks for that I just came back from the local Kubota dealer and they confirmed what somebody else had already said that there is no such thing as a drawbar for the American Kubota tractor only Canadian so looks like I'm going to be making one cuz I'm not going to spend $60 for a flat piece of metal with a hole drilled in the end of it.
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
1999 Sterling L7501 Dump Truck, VIN # 2FZHRLLB5XAA64093 (A61165)
1999 Sterling...
2001 Vermeer BL2000 Chipper with Grapple (A61166)
2001 Vermeer...
4022CFL (A59228)
4022CFL (A59228)
2019 Isuzu NPR Box Truck, VIN # JALC4W169K7009134 (A61165)
2019 Isuzu NPR Box...
