Beep, Beep, Beep!
/ Beep, Beep, Beep! #1
RTBee
Southern Ohio
RK55 Shuttle Shift
I love my RK55, but backing up is a little more than annoying. With this size tractor I guess they feel it should have an incredibly loud beep when backing up. I use my tractor on my own property, not for hire. I do not do any kind of commercial work. Does anyone know the best way to disable the backup beeper? I'd love to be able to just add a switch to turn it off or on, though I'm not opposed to just disconnecting it. It's too loud for me to locate it, physically on the tractor (sounds like it's everywhere) and I can't find a wiring diagram to run it down. Any thoughts or suggestions would be appreciated.
/ Beep, Beep, Beep! #2
Wear earplugs while you look for it. Also, with earplugs in, hold a short pipe to your ear and point it around at the tractor. It will focus the sound.
/ Beep, Beep, Beep! #3
It’s probably at the back end of the tractor. It shouldn’t be hard to spot it unless they’ve really stepped up their game.
/ Beep, Beep, Beep! #4
Maybe ask Mike Morgan how he disabled his? I do not recal whether he covered this in one of his vids.
/ Beep, Beep, Beep! #5
Some beepers had an adjustment screw in them.
Or just unplug it when you find it.
/ Beep, Beep, Beep! #6
On the TYM 454 its behind the seat under the fender.I unhooked mine.
/ Beep, Beep, Beep! #7
on my skid steer i just went to the speaker in the back of the unit and unpluged two wires. I then neatly taped the wires out of the way and to protect them. it would be easy to re-hook if someone wanted to.
/ Beep, Beep, Beep! #8
On the Toolcat, I slipped a thin piece of rubber down between the mount and the beeper. Can't hear it in the cab, but still loud enough to warn anyone behind it. :thumbsup:
Before:
After:
/ Beep, Beep, Beep! #9
if you are capable of doing electrical work
once you find the speaker measure the resistance of the speaker
solder or crimp in a resistor of equal value in one of its wires - pos or neg doesn't matter
this will cut the voltage to it in half therefore lowering the volume
if still too loud use a larger resister
/ Beep, Beep, Beep! #10
Or just cover it with tape.
/ Beep, Beep, Beep!
A lot of great ideas! Now I have a place to start. When I find the speaker, I think I'll trace the wires back and install a switch. On/Off. That way should I ever be using it around others or commercially, I can just switch it back on.
I'm about 200 miles from my tractor. I live in Indiana, but have property in Southern Ohio (where I keep our tractor). So when I get back there in a couple of weeks I'm going to tackle this issue. Thanks to all for the tips! That's one of the great things about a forum like this. Many are here just to help each other out and pick up tips and tricks or share positive experiences with whatever!
/ Beep, Beep, Beep! #12
Let me know when you find it, Id like to disable or install a switch on mine as well.
Thanks man
/ Beep, Beep, Beep! #13
If you send me a private message I will tell you how to disable. The backup alarm is not a mandatory safety feature.
/ Beep, Beep, Beep!
Thanks man
I have been given the info to fix the issue. If you'd like to know, let me know and I'll forward it to you via private mail.
/ Beep, Beep, Beep! #16
the alarm is on the back of the tractor on the inside of the left fender(if you are looking at the back of the tractor). there is a rubber flap just above the lift arm and the alarm is behind that rubber flap. i would love to know how to disable mine as well. any info would be greatly appreciated, that thing is annoying.
/ Beep, Beep, Beep! #17
I'll PM you.
/ Beep, Beep, Beep! #19
Before:
After:
Good idea! I sat a plastic jug on mine but it still is too loud. I like having the alarm to alert a near-deaf dog and the wife of my movements.
/ Beep, Beep, Beep! #20
From the rear of the tractor. Just to the right of the left rear tire, between the axle and the bottom of the cab, look for a connection of two wires, red and green. Disconnect and tape up the ends.
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2022 EZ-GO ELITE...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
