PTO truning when off on JD 4500
/ PTO truning when off on JD 4500 #1
cshonea
John Deere/4500
PTO will continue to turn with switch off. Not able to stop with hand pressure. Not sure if its the switch or something more serious. Any recommendations before send to a repair shop?
/ PTO truning when off on JD 4500 #2
Not able to stop with hand pressure. Any recommendations before send to a repair shop?
Just one,,,,,,,never touch the pto shaft on a running tractor,,,,,,never.
/ PTO truning when off on JD 4500 #3
:welcome: to TBN
Here is a pic of the theory of operation.. may help you understand what may be going on.
Sounds like a check of the PTO solenoid is in order. Because I'm seeing it in the service tech manual, have added that test of the PTO solenoid (parts of two pages)
/ PTO truning when off on JD 4500 #4
Reading the theory of operation post by beenthere (thanks) it sounds like your PTO solenoid is staying engaged. It could be still energized or stuck in the engaged position.
Unplug the PTO solenoid, then see if the PTO stops. If not, it's not the switch.
/ PTO truning when off on JD 4500 #5
The clutch disc brake pads are broke and or shattered.
My 4700 does the same thing.
It made a ratcheting clicking sound a few months b4 finally quieting up.
I suspect the parts fell into bottom of trans housing. IDK. I never tore into it.
/ PTO truning when off on JD 4500 #6
There are a couple of problems with solenoid operated PTO's;
1) depending on design the engagement can be harsh on light loads
2) when being shut down on high inertia loads such as brush hogs or generators the brake gets a lot of use and wear
Although not usually deemed necessary an overrunning clutch will save a lot of wear on the pto braking system.
/ PTO truning when off on JD 4500 #7
Most ppl Engage or Disengage Elc PTO at way too many eng rpm imho
Steiner 60in Fairway Mower Tractor Attachment (A64553)
Steiner 60in...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
