Buying Advice Suspension/Shock absorption
/ Suspension/Shock absorption #22
Interesting...it's almost like there is air in the system how the cylinders can move.
/ Suspension/Shock absorption #23
It's a nitrogen filled bladder, actually
/ Suspension/Shock absorption #24
Aahhhh. So, you flip the switch and it opens the passageway to the bladder chamber and you get the cushion, otherwise it just acts normally. It sounds like a HD version of the hammer arresters they put on water pipes.
/ Suspension/Shock absorption #25
Similar. They are called Hydraulic accumulators and work as you described.
/ Suspension/Shock absorption #26
Kubota offers it as an option starting with their M6 series. I have a M7 where it is standard in the Premium KVT models. It is fantastic. Front suspension with double cab isolation along with air seat really help a 72 year old’s back.
/ Suspension/Shock absorption #27
I知 trying find a smaller tractor (50-80HP) that has ride suspension. Not an air ride seat. True suspension. What痴 the smallest tractor the offers this? Mine tears my back up even with low tire pressure. Use of tractor is mainly bush hogging and light farm work.
Don't know of any in the USA that offer axle suspension. A combination of "air suspended seat and optional "comfort ride control " make the Deere 310 ride smoothly regardless of of the terrain or load. It doesn't have a 3 pt hitch, but the backhoe and loader work better than most.
/ Suspension/Shock absorption #28
Never saw it in a tractor but wasn't looking all that hard. Found it in my Ferris ZT. But I added to it with extra springs on the seat and large balloon studded tires for soft ride and traction. Since implements connect to the main frame proper which is the castings of the engine, tranny, hyd section and differential, any soil deviation would put the implement and main frame at odds.
2015 CATERPILLAR AP1000F ASPHALT PAVER (A65056)
2015 CATERPILLAR...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2019 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2019 HINO 268 4X2...
PORTA POTTY (A68842)
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
