Mahindra Max 28... Not Starting !
/ Mahindra Max 28... Not Starting ! #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
Hello to all the people reading my post ! It has been a while but the SoCal remodel took far longer than expected and in a way is still on-going, barn wiring, Forge Setup, and the new compressor system !
My Max 28 took a fit and decided not to start.
It has been giving me trouble starting for a while, if I bounce on the seat it would start... Seat Safety Switch right, that was my guess.
I jumper the Seat Switch out and the engine started but as soon as I let go of the key, from the start position, the engine stopped running.
Any suggestions ?
Thank you to all for your comments !
/ Mahindra Max 28... Not Starting ! #3
If it’s the same Mitsubishi motor as the smaller max it’s probably the stop solenoid on the injector pump. It has a pull in coil that energizes when the key is turned then a holding coil to keep it open when the key is released. It’s a common issue on the Max. There’s a number of posts in the Mahindra forum.
/ Mahindra Max 28... Not Starting ! #4
My stop solenoid partially went on mine back in 2015. It did not burn out, but would never consistently pull back to the same position. Dealer took care of it under warranty, but drove him crazy determining the problem.
Thanks guys I will check the Solenoid and the Mahindra Forum.
