Todays shop time.
/ Todays shop time. #622
I've been working this summer from time to time on finishing my pole barn so that I can eventually heat it. Decided to take a break from that and get a project done that I have been wanting to do for a year. I am something of a organization freak and have hated lumber leaning against walls or in stacks on the floor, so I finally built my wood rack.
The back has an 8" gap for plywood. The front has four shelves for lumber and then there are some cubbies for shorts.
Of course I just noticed that I still need to go back and add some more lag bolts where I am hanging it from my loft. Sounds like a good reason to check the mini-fridge again tomorrow. :laughing:
/ Todays shop time. #623
Oooooooo. I really really really like that. How far out do your horizontals extend?
/ Todays shop time. #624
Thanks, I think it'll work out good.
They extend 18.5" so that a couple 2x10's can lay down (on the top shelf) side by side. Other than the the magic behind me picking that number is I had several scrap 2x4's at that length that I decided to use for it. :laughing:
Difficult to see, but there are a few cubby places for bits and pieces to fit in. I am really going to like that. Seems I always have scraps that are a couple feet and I know I will use them down the road.
I figure the 8" gap for plywood in the back will hold a couple new full length pieces as well as plenty of scrap pieces. So that should work out.
/ Todays shop time. #625
Unipunch C frames are always available on eBay but I couldn’t find any info on utilizing them without a proper press brake.
unipunch - Google Search
I came across some locally and decided to see if I could use them in my hydraulic press. The four frames I got were “B” series and capable of 1/2 inch holes in 10 gauge.
I drilled pilot holes in my bed plate for frame alignment.
/ Todays shop time. #626
Always wanted to happen across some Unipunches for square hole punching, etc. Need to do some research to understand what I can do as far as thickness/dia hole sizes with my 20T press.
/ Todays shop time. #627
Pls. keep us posted on what you learn. I suspect a few of us have 20-ton presses. :thumbsup:
/ Todays shop time.
I built a crane for my wood splitter. I’ve never used that method before so we’ll see how it works.IMG_0048.JPG
/ Todays shop time. #631
Question for some of you here. If I need to start a new thread I will just tell me.
I’m getting ready to redo some 4-wheel wagons for hauling round bales of hay. Never understood load tables. No engineering background.
I’m wanting to use either 2x8 c channel or box tubing for the main frame runners. I’ll have a span of about 12 feet. 16 foot beds. Currently bales are about 1,000lbs each. Would like to haul 8 bales and also be able to upsize bales in future. What thickness steel do I need? I’m thinking 3/16.
The 8 inches is to clear the tires on one wagon frame. It’s a low rider. Then use 8 foot lumber for bed.
Currently they’re using 3x8 oak.
/ Todays shop time.
I’m not an engineer yet, but I tend to overbuild things. The cost of totally scraping or straightening and reinforcing a frame is astronomical compared to just using 3/8 thick.
/ Todays shop time. #634
It’s surprising how many foot switches for various machines I have “floating” around. I spent the weekend building enclosures, adding handles and mounting one permanently to tidy things up and in general making them more user friendly.
I have a few more to go but I’m done for the day.
/ Todays shop time. #635
Nice Terry! ...funny I was just messing around with one of foot switch pedals today trying to see if I could get it to function for both my porta-band saw and my 20T press.
I did finally get my press brake painted after fabricating the Swag kit a few years ago... I thought the red paint would be a good 'warning' color. Surprised I still found the Swag decal that I waited to apply after paint. Yeah, the fluorescent shop light zip tied to the press is a bit red neck but until I find a LED solution, it will do.
/ Todays shop time. #636
The paint looks good, Mark! You didn’t get the “finger” brake?
/ Todays shop time.
I got some channel iron. There’s 16 pieces of 6” 4 4” pieces plus a few pieces of angle iron. The channel iron is 1/4 wall, 10” long and I gave $170. I plan on using some of it to build a custom trailer for my Grasshopper.IMG_0081.JPG
/ Todays shop time. #639
Good find indeed. All painted for rust protection too. You must mean 10' not 10" though.
gg
/ Todays shop time. #640
I had a remote spin on filter left over from something I had disassembled long ago. I decided to mount it on the rear of my 33 year old solvent tank for filtration beyond the mesh strainer most of them have.
The photos show how handy a high lift pallet jack comes in.
93b (A65054)
93b (A65054)
PORTA POTTY (A67714)
2003 Toyota Sequoia SUV (A66738)
2003 Toyota...
2025 JMR Stump Bucket Skid Steer Attachment (A66734)
2025 JMR Stump...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
