Discarding used hydraulic/transmission fluid?
   / Discarding used hydraulic/transmission fluid? #11
I had 10 gallons, so I took it to the county recycling center. Not two words were spoken. I just didn't want rolling eyes or a hassle at the WalMart.
   / Discarding used hydraulic/transmission fluid? #12
I take mine to Walmart (3 different ones in my area), they have always taken it cheerfully, and even returned my buckets. (I save 5 gallon buckets)
   / Discarding used hydraulic/transmission fluid? #13
I imagine like a lot of people on TBN, I do not have garbage pickup service and take garbage and trash every 10 days or so to the county recycling center. They have containers for auto oil and cooking oil and I dump the hydraulic oil in the auto oil container. My local Auto Zone stores also have oil recycle containers.
In Washington the county dumps also take most fluids. The auto parts store do too but most of the time your limited to 5 gallons a visit. Our dumps allow 10 gallons. But, if they are not looking.... :)
   / Discarding used hydraulic/transmission fluid? #14
Yep, that is what I do. The transfer station I go to has an attendant watch you dump it if they are not busy.
   / Discarding used hydraulic/transmission fluid? #15
I guess I am an oddball. I take it to my fire pit when I light a fire and I just keep pouring it over the fire until the hydraulic fluid and engine oil is all burned up. I don't have to haul it or store it, and it makes a GREAT fire starter if mixed with about 10% gasoline. I call this cradle to grave....LOL. We took it from the earth, I gave it back. I also used to pour it along my driveway to try and slow down the weeds, but it's not effective at that job. I found that telling the local tree guys that they can dump the mulched up trees here works well. I typically have 2-3 feet of mulch on the bank below my 250 foot driveway. That does a far better of keeping down growth. Maybe I should start oiling that mulch as a 1-2 punch?
   / Discarding used hydraulic/transmission fluid? #16
I use it as chainsaw bar oil............or burn it in my woodstove (used oil burn procedure I found works safely and I get the winter heat.)
   / Discarding used hydraulic/transmission fluid? #17
I burn my old oil of all types. I built a drip system in my shop wood stove. I even take friends used oil. Autozone gets the water,antifreeze and unknown blend back in oil containers.
   / Discarding used hydraulic/transmission fluid? #18
In reality, the ones here are to lazy too watch and they much prefer their coffee :)
   / Discarding used hydraulic/transmission fluid? #19
Bar oil, that's a great idea.
   / Discarding used hydraulic/transmission fluid? #20
If you have a Stihl or other with adjustable oil pump, turn your oil pump up to maximum, hydraulic/engine oil has no tackifier in it so it doesn't hang on like bar oil. I drop last bits of containers of diff oil, used hydraulic fluid, engine oil, all in one container and mix with some bar oil if I have it, then just keep adding to the mix. Yes the mix has little or no tackifier left, so I run my pump at max!
13ft S/A Utility Trailer (A56859)
13ft S/A Utility...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
7ft. Bobcat Skid Steer Blade Attachment (A55973)
7ft. Bobcat Skid...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2015 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
