RNeumann
Elite Member
They probably are not the sharpest knife in the drawer but they would probably use chairs if it was their own pour. You want rebar in the tension portion of the concrete and on the edges of the pour that is higher in the slab. It does little to no good in the center and bottom there.
When you say “They probably are not the sharpest knife.....” (implying they lack intelligence), what generalization were you making? Race, ***, religion, nationality? Or were you just implying people who work with their hands aren’t smart?
The OP has stated the concrete will be “tailgated” (no pump) and the concrete truck will be inside the structure to lay concrete in the back. This means the rebar needs to be against the ground until the truck pulls out of the structure. At that point some would just lift it and others would take the time to add the “chairs” or “dobies”. Both have advantages and disadvantages and without a specific spec or contractual note it would be up to the contractor. Either way I’m sure it will end up in the slab- not on the bottom.
But heck, I’m not too sharp. All I did was read the posts (especially the OPs).
