DPF service life
/ DPF service life #1
4tillingdirt
nc
N/A
Just wondering if there is expected service life before the DPF has to be replaced or cleaned?
/ DPF service life #2
I heard numbers batted about and "normal expected life span" used in various forums. There is an expected difference between having the DPF routinely cleaned and having it replaced. I've read numbers anywhere from 5K hours up to 10K hours. Some DPF systems have replaceable filters - some must have the system replaced.
However - trying to pin it down to a specific time - is rather like trying to catch a fart and paint it green.
/ DPF service life #3
The average residential tractor clocks eighty (80) engine hours per year, according to stats quoted here from industry studies.
5,000 hours / 80 hours = 62.5 years.
DPF replacement will seldom be an issue for first or second owners of residential tractors.
Emission abatement technology will improve and probably simplify over time or we may operate electrically powered tractors in the future.
/ DPF service life #4
Agree replacement should not be required untill thousands of hours on the clock.
The residential tractor term has no reference in the tractor industry?
/ DPF service life #5
The owners manual says that for the "initial 100 hours of operation: The regeneration process is automatically performed as necessary during driving or operation. After 100 hours of operation: The regeneration process is automatically performed for every 100 hours of operation during driving or operation (under normal/high load condition). The regeneration process may not be automatically performed if the vehicle is repeatedly used under a very low load condition after initial 100 hours of operation. In this case, start the process manually".
So it seems as though it varies depending on what you do with your tractor (heavy use or light, idle use). I've put about 80 hours on my RK55 and I've had it for right at a year now. It's regenerated once at around 38 hours, but not since. If it only does so every 100 hours or so and if 'oosik' is correct, then it should probably last several years before I need to worry about replacing or servicing it. I don't know about cleaning it, I guess I'll see as time goes by.
/ DPF service life #6
I think Jeff has hit the nail squarely on the head.
/ DPF service life #7
i bought a kioti and asked about teh DPF system - all auto, probably replacement about 3000 hours. (filter only I thinkm ,they said $300ish). They have yet to replace one at the dealership - BUT - if 80/hours a year is correct and tehy've been selling them at most 6 years..that's under 500 hours. So yeah, nobody has enough time on a tractor to have any idea how long they last, or what the symptoms of a 'need a filter' are.
I was told keep the revs up when using the tractor, to keep the exhaust hot and reduce particulates and load on the filter. First regen was 38 hours, second at 71. I'm at 84 hours as of yesterday.
I can only relate what we have to do at work on IC school buses - 10-15% have issues, IC says it's bad sensors...we'll see. Those buses that never 'leave town' seem to have more issues than those that make trips on the hiway. Our tech says about 20 minutes of highway use (constant high rpm) seems to 'clean them out real good'. A filter is $900 on a bus.
/ DPF service life #8
Keep in mind to, The DPF is covered under their 8 year powertrain warranty. That is a huge peace of mind for me.
Also, I had a Massey a few years ago that I swear regened every 5 hours. It seemed very excessive.
/ DPF service life
Good thing I hear about Masseys with the new 1700 premium series coming out this Fall is that no more regen. They have done away with DPF.
/ DPF service life #10
I saw that. Before I found out about RK, I was pricing out Massey, and a few others. I was quoted $37900 for a 1755M Power Shuttle. I like the idea of the power shuttle. I just couldnt justify the $9,000 Price difference between the RK55 Cab and the 1755M Cab.
/ DPF service life
Yeah Masseys are not cheap. One other thing I don't like about Massey is that when you get the 1760M that is replacing the 1759, you can't get a hydro on the open station and you have to use Cat 2 implements. However on the cab it has Cat 1 - stupid if you ask me.
/ DPF service life
What I don't understand is that if manufacturers can meet emissions requirements without a DPF and a regen, why not go that route like Massey is doing with the Shibaura engine.
/ DPF service life #14
Don't understand reference to mandatory CAT 2 implements.?? Simply use a reduced bushing. My MX is cat2, before purchasing Pat's quick hitch, I just used the bushings. CAT 1 implements work fine using The bushing.
The DOC catalyst emissions must be developed and tested by each individual Engine producer. This is an expensive process. The DOC uses more aggressive EGR which some folks feel is harmful to cylinder liners. DPF is the easier path to compliance.
RK did not offer HST on their 55 hp open station but they have now seen the light, revised the specification. Massey will also if demand is demonstrated.
Deere Utility R series and up, Bobcat Corp, Mahindra also use DOC now, instead of DPF. Maybe others?
/ DPF service life #15
Both routes have positives and negatives. DPF route is cleaner and greener, but uses fuel to do a regen. DOC/EGR will lead to more soot in the intake, EGR issues, not as clean emissions. Go to the Mahindra forum and look at the EGR problems they were having on brand new tractors. Mahindra is on their 4th or 5th update for the emissions. Even some gasoline powered cars made today have Gasoline Particulate Filters (GPF) on them. Direct Injection gas engines produce a lot of particulates.
/ DPF service life
Didn't know they had bushings so you can use Cat 1 implements. I guess Massey feels that the 1760m is the crossover point to the full size tractors so maybe that is why they just offer the power shuttle. Power shuttle might be ok, but seems like more to tear up and then you still have to use the lever just not clutching.
