Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #41
You're daft. no one would do that......
For the record, this was not my idea.
   / Anyone drilled a hole in the end of a pallet fork #42
To accept a trailer ball for moving trailers around? Sounds like a reasonable idea unless I'm missing something.
Drill the hole and then weld a stiffener onto the bottom side of the fork.
Good luck and be careful out there.
   / Anyone drilled a hole in the end of a pallet fork #45
I highly recommend against it. I did this on my old forks and the one with the hole and trailer ball over time got bent down. Not a lot but enough to make picking up pallets difficult. I never could get it straightened so I eventually got new forks and welded up a trailer mover that slips over both forks.
Exact same thing happened to me....
   / Anyone drilled a hole in the end of a pallet fork #46
Cutting branches directly overhead while standing on a raised FEL bucket..... get hit by the branch first and get knocked off the FEL second. I hope someone had a phone to call 911.
   / Anyone drilled a hole in the end of a pallet fork #47
Like I said, wasn't my idea. However, the 2 branches being cut were long but skinny (see pic) and were hanging straight down by just a thread of bark--they got torn by a storm--and the tips were almost touching the ground. So not quite as dangerous perhaps as it appears at first glance. I could pick them up with one hand, so prolly not enough heft to seriously hurt anyone. In any case, I hired pros to do it, this was their best idea, and it was done without mishap. (This same crew also took down a dangerous, big heavy branch that had fallen on my house in the same storm, and they took all precautions, used ropes, sawed each branch into a zillion pieces starting at the ends, etc., and took hours to do it.)
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
Wacker Neuson ST45 Skid Steer - Powerful Compact Loader (A55302)
Wacker Neuson ST45...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2003 CATERPILLAR 924G WHEEL LOADER (A52706)
2003 CATERPILLAR...
