Oil & Fuel fuel filter installation
/ fuel filter installation #1
rogern
case 580c
I purchased fuel filters for my case 580 c backhoe (primary and secondary) but instead of the threaded air/water bleed screws that
i have on the old filters there is a 1" dia+/- plastic disc with two plastic ears and a plastic 1/16" to 1/8" dia. hollow nipple about 1/4' long.
It looks like the plastic ears are there to grasp to rotate the plastic disc, but I will not rotate and I am afraid I will break it if i apply too
much torque. My local case dealer was not much help on this.
/ fuel filter installation #3
The ears will be there to undo, but can be very tight.
On a separate issue/thread hijack, does your C have the switch on top of the loader joystick to disconnect the transmission?
/ fuel filter installation #4
Yes the ears are there to grab ahold of & turn.. I HATE those things.. THEY BREAK.. KEEP an extra one on hand..
okay, i will try to turn it without breaking it. Thanks.
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2013 Bobcat T750 (A64047)
2013 Bobcat T750...
KIOTI CK27 TRACTOR (A62130)
KIOTI CK27 TRACTOR...
Bobcat LT113 Mini Skid Trencher (A61166)
Bobcat LT113 Mini...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
