LS XR4140H Regen intervals
   / LS XR4140H Regen intervals #11
It's been 5 yrs on mine and I barely notice that it's even occurring.
You'll be the same way.
Enjoy!! They're great tractors!!
My third region happened at 29 hours after the second. The Tractor is now at 76 hours after 8 weeks. Loving the tractor so far.
   / LS XR4140H Regen intervals #13
I had a weird thing happen around 21/22hrs. Started getting a weird burning smell, maybe like burning paint but not quite. I noticed one of the regen lights (the one with the thermometer) was on and believed I had just experienced a regen. I'm still not sure if I did or not. After the light went away, so did the bad smell. I came here to the forum and discussed it a bit; found out that a regen involves two lights on at the same time. Yesterday around 30hrs I noticed another burning smell not quite like the first. I was waiting for it to do regen but it didn't, just kept stinking. So I did a forced regen. I did it out of curiosity. Not sure if that's bad for it or not. But the smell is gone now.
   / LS XR4140H Regen intervals #14
According to my manual page 3-55 (XR4100) you should only have the dog regeneration indicator on in most conditions-if you have more than one on or the dpf regen is blinking the tractor is telling you something about your DOC and DPF
   / LS XR4140H Regen intervals #15
The first light comes on to indicate the DPF is being heated up. When the second light comes on the regen. cycle has started. When the cycle is over, both lights go out.
   / LS XR4140H Regen intervals #16
Not according to the XR4100 series op manual pages 3-55 through 3-57. According to the manual the only time two indications (one of which is the regen active indication) are on is when you have a soot rate over 150%-in which case the engine error warning indicator will also light and power will be reduced.
That being said it wouldn’t surprise me if the manual was not correct
   / LS XR4140H Regen intervals #17
I’ve only had a single regen. cycle on my XR4155HC at 50.0 hours and didn’t really pay much attention.
The description, in my previous post, was how the regen. worked on my XR4046HC and I “assumed” was same on the XR4155HC.
My apologies. I suspect the manual is correct.
   / LS XR4140H Regen intervals #18
That being said it wouldn't surprise me if the manual was not correct
How old is your LS and What is the P/N and date code on the back cover of your manual?
I have:
2017 XR4140, purchased new 06/2018
manual P/N : 52116804-03
manual Date: 20150000
My manual makes ZERO reference to the DPF temp lamp. Only the regen and regen inhibit lamp. And for a 150% soot condition it says the DPF lamp will flash fast.
The original manual for my tractor was lost by the dealer before I purchased the tractor; this one I have was ordered by the dealer two months ago, directly from LS, and then forwarded to me. To me, this means it should be the most recent REV of the manual. But the date on it is 2015. I knew it must be dated information (not showing all the lamps, plus other issues) but I assumed it just hadn't been updated by LS since 2015. Now the things you're quoting from your manual don't match what's in my manual, and I wonder if you've got a more recent copy than I do.
The only indication I have to the function of the DPF temp lamp is the sticker on the fender, which ironically suggests the opposite of the sequence quoted below:
rlgustafson said:
Re: LS XR4140H Regen intervals
According to the sticker, Regen lamp comes on when it needs to regen, temp lamp comes on later when it's up to temp to perform its intended regen, and then it regens.
I can't confirm the sequence suggested in my manual, or the one in GSVette's manual, or the one on the sticker, OR Gustafson's observations. So far (only 30hrs) my only experience with auto regen was when the DPF temp lamp alone came on and I'm still not sure if regen occurred.
It would be nice if the documentation provided by LS was clear, consistent, and accurate.
20180822_140451.jpg20180822_140436.jpg20180822_140425.jpg20180822_135747.jpg20180822_135714.jpg
EDIT: Personal observation... when I forced regen, both lamps were on for the duration. Not sure if this has any relevance to the auto regen sequence.
   / LS XR4140H Regen intervals #19
I have:
My manual makes ZERO reference to the DPF temp lamp. Only the regen and regen inhibit lamp. And for a 150% soot condition it says the DOG lamp will flash fast.
The only indication I have to the function of the DPF temp lamp is the sticker on the fender, which ironically suggests the opposite sequence quoted below:
I can't confirm the sequence suggested in my manual, or the one in GSVette's manual, or the one on the sticker, OR Gustafson's statement. So far (only 30hrs) my only experience with auto regen was when the DPF temp lamp alone came on and I'm still not sure if regen occurred.
View attachment 568006View attachment 568007View attachment 568008View attachment 568009View attachment 568010
Did you read my last post?
   / LS XR4140H Regen intervals #20
I think I was composing my reply while you posted yours, so I didn't see it until now.
I致e only had a single regen. cycle on my XR4155HC at 50.0 hours and didn稚 really pay much attention.
The description, in my previous post, was how the regen. worked on my XR4046HC and I 殿ssumed was same on the XR4155HC.
Whose manual are you confirming? My manual doesn't match his (or the sticker)
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2017 Ford F-450 Crew Cab Mason Dump Truck (A55788)
2017 Ford F-450...
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
Flat bed utility truck with inline 6Cy engine (A55301)
Flat bed utility...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A55788)
2016 Big Tex 14ft...
