Reinstalling Loader Question
/ Reinstalling Loader Question #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I had my loader off yesterday and was just about to coat the retaining pins with a thin coat of Never-Seize before I remounted it. Then I thought this might not be the best thing to do - I better ask. It is 18 years old and the plating is starting to wear off in places on the pins. So leave them dry or Never-Seize them and risk dirt entrapment ?? The movement in the joint is very slight and not rotation so I don't know why grease would be a problem ??????? Thanks
gg
/ Reinstalling Loader Question #2
I wouldn’t grease it because it’ll make a mess next time you take it off. Those pins don’t swivel so I don’t see the good that could come from it.
It is just that I have heard of pins being frozen in place and very difficult to remove requiring extrodinary measures.
gg
/ Reinstalling Loader Question #4
gg
have never seen that on any of mine The tolerances are not super tight.
/ Reinstalling Loader Question #5
Every pin I have on my Kubota FEL has a grease zerk. They all get goo'ed up with nasty black grease every ten hours. I see no problem coating your pins with Never-Sieze.
I had my previous tractor for 27 years - goo'ed all the zerks on the FEL every ten hours - no problems - they did collect dust(volcanic ash over in this area) and it never hurt anything one bit.
When I start getting grease spots on my work clothes - I go around with a couple shop rags and wipe all the excess off.
/ Reinstalling Loader Question #6
I’ve owed 3 Kubotas and worked several more. None had grease fittings on the loader mount pins.
/ Reinstalling Loader Question #7
I only use never seize for the most demanding situations. It's just nasty stuff and gets all over your hands!
People don't use anything and then think they have to use the never seize, going from one extreme to the other. ANY grease will usually do. I use white grease on stuff like electrical screws so it doesn't make such a mess.
/ Reinstalling Loader Question #8
4570Man - you are absolutely correct. My mount pins do not have zerks.
/ Reinstalling Loader Question #9
I call that stuff tin man in a can. There’s no way I’d do anything with these pins. Unless you brake cleaner them and the holes after every time you take it off you’re doing more harm than good.
/ Reinstalling Loader Question #10
Loctite makes dry graphite spray for applications where one wants movement to occur without the wet effect of grease/anti-seize.
When I use anti-seize I used Wurth brand, the German made copper base anti-seize. I used to buy it by the quart sized tins when I had my Foreign auto shop.
Can't hurt to 'lube' the pins with something, especially since you are seeing wear. I lube the ones on my Kioti.
/ Reinstalling Loader Question #11
The pins are under shear force load only. There’s zero rotation. I don’t see the grease helping anything.
Thanks for the discussion here. The reason I asked was to make sure there was no glaring reason I should not use grease. Many times I have been very surprised by what I have learned here - this is good place to just ask stuff and see what comes back. Anyway, I live in a part of the country where half the world is covered in road salt 6 or 7 months a year. We worry a lot about stuff we want to be able to take apart. Especially non-moving stuff like those pins, that are directly exposed to the salt enviroment and may sit for a long time before they need to be taken apart. To me, a little mess is nothing compared to a frozen joint. But used sparingly why would there be a mess. If the pin comes out easy you don't even have to touch the greasy part. Some of you may remember a guy who called himself RedHorse on here way back. From southern NH. He bought a used Kubota and if I remember correctly his loader retention pins were froze so badly he could not get them out. You guys that live where you don't have to think about road salt and chlorides don't know how lucky you are and I can understand you questioning my wanting to use grease.
gg
/ Reinstalling Loader Question #13
IMG_20160828_021208.jpg :laughing:
/ Reinstalling Loader Question #14
That's funny.
It's not quite that bad. I learned not to touch my face or put things in my mouth a while back already.
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2011 Ford F-550 Cab and Chassis Truck, VIN # 1FDUF5GT9BEB33435 (A61165)
INOP/NON-RUNNING...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
