New seat installed
/ New seat installed #1
Sun Treader
Member
Western Virginia
Case IH 495
Group,
I posted a question about whether anyone had tried this particular seat:
Amazon.com: VEVOR Suspension Seat Adjustable Backrest Headrest and Slide Rails Mechanical Suspension Seat Foldable Heavy Duty for Tractor Forklift Excavator: Home Improvement
No one had so I went ahead and gave it a shot. This is a replacement for the stock seat on my B2601. The stock seat is terrible. Hinged at the front with a couple of uneven springs on the rear so its always trying to bounce you forward. The retractable seat belt is mounted to the seat frame so every time you bounce it tightens on you meaning you've got to unbuckle all the time to get some slack. I didn't find the seat itself too uncomfortable, hard vinyl works for me, but everything else was terrible. Suspension seat was called for. Air would be ideal, but too expensive for my hobby tractor. I put about 100 hours a year on it.
I did all the research I could on what was out there. Grammer is the gold standard, but over a grand, too much. The Black Talon seat at Northern Tool looks to be identical to the generic one I ordered but with a different suspension, upgraded arm rests and a retractable seat belt. eBay has many versions of this seat with different options. I even saw a few stock Kubota models that look to have this identical seat. This all led me to believe its a pretty generic seat that can be speced for different customers. Even on Amazon there are half a dozen vendors.
One concern brought up was the height of the seat. The seat on the B series is deceptively high up. I measured 10" from the base to the top of the seat bottom. The new seat has three adjustable basic heights with 4" or so of suspension travel. The dimensions all worked out. Its a fairly narrow mounting area on the tractor and the dimensions fit there as well.
The seat came quickly and weighs in at 80 lbs. Its a substantial piece of kit! the stock seat came out easily enough. Its just two brackets bolted to the tractor.
As always not a single bolt and hole form the old lined up with the new. I retained the stock brackets because they lined up with the threaded holes in the tractor and gave a level mounting area. The rear bracket only needed to have two holes elongated to line up with the sliders in the new seat.
The forward bracket needed a plate fabricated to get from the brackets connection to the new seat's mounting holes. No problem, scrap piece of steel lying around, drilled some holes. Its not pretty and took a couple of tries from some mismeasuring but its hidden by the suspension skirt. No big deal. Gave the plate some primer and black paint. The longest part of the install was waiting for the paint to dry.
The only interference issue was the PTO engagement lever was just scraping the side of the new seat sliders. A Couple of washers between the brackets and the seat solved that. I also could have ground a little half circle into the lever edge.
The initial concern about the seat being too high was increased because I reused the original brackets which brought the mounting base up then added additional thick washers to clear the PTO lever. Even with that the seat height is just fine. At rest with the seat in its lowest setting its at about 12" above base, so about 2" higher than before. With me in the seat it settles right down to 10", same height as before. With the suspension travel (of which the stock seat had none) I move up and down from about 2" below stock seat height to about 2" above when really hitting the bumps. That's with the seat set at its lowest setting. Going to the higher settings still feels good. With the original seat I kept the tilt steering wheel at its lowest setting, with the new seat I keep it at the lowest with the lowest setting of the seat, with the higher settings I put the wheel in the middle of its tilt.
Final verdict is a night and day difference in riding around. I don't have to brace myself when I know I'm coming to a bump, I feel like I'm gliding along rather than pounding along. With all the adjustments I can position myself right where I used to sit, closer to the dash, higher than before, can recline the seat a bit. Its all very comfortable and completely different than stock. That stock seat, wow, its terrible. It'll install it to replace the even worse seat on my 3-point backhoe that goes on the big Case. Instead of each bump trying to toss me off forward and compressing my back, now I just float up and down.
For the seat comfort I'm not finding myself slumping forward anymore, being a little higher is letting the controls fall to hand easier, the loader level was a reach up before. This isn't a plush seat, a little cushier than the stock one, softer vinyl, more padding, but no one would call it plush but I like a firm vinyl seat so its good for me.
The big test will be how it holds up, it strikes me as pretty robust and I'm a light-duty user so hopefully for a very long time. I think its a good fit for the SCUT and CUTs, would fit on my Case 495 great, might start feeling a little small on the larger utility tractors.
So for a little less than $300 I'm more than pleased; similar seats with a few upgrades seem to go for $500-$600; with the really nice stuff starting at about $800-$1200. For the cost its a huge upgrade.
David
/ New seat installed #2
Thanks for the post!
Is it a knuckle buster to change the seat spring tension?
Do you know if they have a swivel option?
The seat tension adjustment is a big easy knob on the front so no problems there. I don't know if there is a swivel option, its probably out there somewhere if you look hard enough.
Did some grapple work this evening and the new seat is just great, what were they thinking with that stock seat, forward hinge and uneven bed springs in back, just a recipe for all sorts of discomfort.
/ New seat installed #4
Case IH isn't the only one who specs poor seats.
Kubota really pinched pennies for a long time on their seats.
Stock seat in my "Grand" L is awful. Had to add cushions bottom and back.
Nothing reasonable fits in there, only M models can take the thousand dollar Grammer seat.
So, this is a very interesting thread, thanks to OP for sharing.
If one is willing and able to make an adapter plate, this looks promising to all of us with uncomfortable seats.
I have Milsco/Michigan Seat's 329 dollar mini suspension seat on my JDX750 as a 600 dollar factory option (gosh those JD decals are expensive...;)) and as standard seat on my F2690e Kubota mower. Fine seat and compact, but neither of two Kubota dealerships were willing to try to install it in my L.
Kubota and other tractor companies are missing out by not selling an upmarket extra cost seat. Sure wouldn't take them much to design their own adapter plate and have it come with the seat. I know they offer better seats on larger tractors, but those of us with subcompacts and compact utility tractors have really missed out. I have a very bad back and spine so avoiding the crash of potholes in lawn would be really great.
/ New seat installed #5
I got the optional Grammer seat on my L3560-the salesman said he had never sold one before.
Will
/ New seat installed #7
I guess that's new, maybe enough folks complained?
thanks
...or a lot of salesman turnover at the dealership because they hire clueless people to sell things already on the lot.
/ New seat installed #8
Bingo!
I sure wish I had a Messicks or something similar near me. Local Kubota dealer is really going downhill, offers zero benefits to employees, so you bet they are jumping ship. Dealer is very old, hasn't kept up with times. Does almost no advertising, etc.
My salesman there had never seen a Kubota F mower before and no showed me on delivery. Just the pits.
And they installed the cruise control wrong where it would not turn off when hitting the brakes
and I almost tore down fencing in a panic. I'm a retired insurance underwriter and oh boy did they dodge a bullet there.
Messicks says they sell over 250 B series tractors a year. Plus who knows how many other Kubotas and New Hollands.
Gosh would I like to deal with that kind of expertise locally.
Unless we are buying white work trucks most of us buy a nicer than lowest level seat for our trucks.
Why would we not want a better seat for our tractors?...
I spent lots of years in marketing and just shake my head at all the lost sales opportunities here.
You bet I want a better seat...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2019 FREIGHTLINER CASCADIA 6X4 TANDEM AXLE SLEEPER TRACTOR (A59909)
2019 FREIGHTLINER...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
