Increasing width of rear
/ Increasing width of rear #21
The only reason I can think of why you may not wish to add to your rear tread width: Particularly using box blades and mowers it is very desirable to have the implement wider than the tread width so your implement will cover your tracks and so you can get closer to the edge of whatever real estate you are grooming.
As I stated in my post. That is why I stopped at 4" of added spacing per wheel. Put me just inside my 60" shredder. No doubt my 2400 is a different critter with wider and weighted rears and 3 pt, when not being used for an implement, different seat, and canopy.
Good points, thanks
/ Increasing width of rear #23
This is a Branson forum, your tractor is a Kubota...different manufacturers, different specifications.
Oops! Sorry. Didn't notice the segregation.
Just so I don't get in future trouble I will only read and respond to posts from my own kind.
Is there a separate washroom for us as well?
/ Increasing width of rear #24
If you're going to act like that, there is.
Now go to your room!
/ Increasing width of rear #25
/ Increasing width of rear #26
Input and advice is fine, don't be so snarky! :)
But quoting manual information from a different manufacturer is pretty much useless...it doesn't apply. That's what I was trying to say.
/ Increasing width of rear #27
Branson axles are huge and stronger than any other brand. It would surprise me a lot if Branson would refer in the manual not to mess with the tractor's width.
Anyway, here is a picture from the F/15 series manual showing the options to get the tractor wider. I have a Operators Manual for the 20 series that my dealer give me by mistake instead of the F series but I don't have it with me at the moment. However it's pretty much the same apart from the dimensions it will get.
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
APPROX (14) 20'-35' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (14)...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
2017 Nissan Sentra Sedan (A61569)
2017 Nissan Sentra...
