F2000 questions
/ F2000 questions #1
LouNY
Super Star Member
Greenwich, NY
Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Evening;
I just picked up a F2000 with the 72" RC72-F20 deck.
I have found the operators manuals for the F2000 drive unit on line.
I have not found the operators manual for the RC72-F20 mower deck.
I'll also be looking for the service manuals for them.
Does anyone have any idea where to find these manuals for a reasonable price?
What is the trick to installing the deck?
It was easy to remove to load in the trailer, but I had heck getting it mounted.
Had to remove the deck to fit my trailer, it was about an inch to narrow.
Anything to watch for on these units?
I did see the issue with bolts on the front gear box.
This unit has an indicated 2800 hours on it.
I had to replace one wheel stud on the rear wheel and nut,
and I found a stripped one on one front one that may be fun to repair,
it's stripped in the hub.
Thanks
Lou
/ F2000 questions #2
I think the gearbox on the mower is getting scarce, at least that's what I was told about my 60" deck. Just keep an eye on all the fluid levels on the ol' gal.
/ F2000 questions #4
it was probably not custom made for that deck, most, maybe all manufacturers would not do that because of the cost.. they would use a gearbox that is already available, and probably still used for other equipment..
/ F2000 questions
/ F2000 questions
I just went to the Kubota website and found the rops,
thanks
/ F2000 questions #9
Thanks, ordered one last night from e-bay.
Another question has anyone added a ROP's or just a shade canopy to theres?
If so any pics on how it was mounted?
I built a shade canopy for mine using 1 1/4" PVC and clamped it to ROPS for under $20. I also built one improved model for my L3901 using front support posts PVC and heavy duty zip ties but can't do the front support posts with the F. Look under my name for posts and find the one for the canopy for a tractor.
/ F2000 questions
Well the ROPS is on order, got the ignition switch figured out so as to get the glow plugs working.
Drained and refilled the front gearbox, pulled the deck belt shields off, need to order a new belt.
Used it for about 3 hours today, mowed good.
2015 Ford E-350 Shuttle Bus (A64556)
2015 Ford E-350...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2004 Brenner DOT 407 Insulated T/A Chemical Tanker Trailer (A64194)
2004 Brenner DOT...
