What is this and how do I fix it?
   / What is this and how do I fix it? #31
Depends on what you have tried. The original "O" rings are not plain O rings and are not normal sized. If you go to the tractor dealer there are two O rings have different part numbers for two different tractors of the same model series. Getting the wrong O ring will make it blow again. I ended up getting both of them because I didn't know which one I had and it is a 60 mile round trip to get there. Also make sure there is no water in the hydraulic oil as that will change the oil viscosity and the O rings ability to withstand the pressure. Purchasing the proper O ring will make a big difference. If that doesn't work. Make sure the engine mount are not at all loose. The valve is mounted to the frame and the twisting of the engine can cause the O ring to blow. Next "what I've done". I went to the hydraulic repair shop and had it checked to be sure the grooves were not damaged. Then I went on line and ordered some O rings that are metric...since the tractor was not made in USA. The ring size that I purchased is :2.4mmX13.8MM Buna-N-90. So far they have been in place for 1 year. I've used front bucket to pick up some items heavy enough that it couldn't life it and they are till in tact. Hope this helps you. Next plan was to make a adapter so the valve is not a direct fit to the pump... via hydraulic hose and offsetting valve. So far not going to have to try that.
   / What is this and how do I fix it? #32
I know this is an old thread, i dont know what I did but yesterday got a leak. Does anyone know the part numbers for the orings and seals I need?
   / What is this and how do I fix it? #33
Go to www.newholland.com
Select agriculture
Upper right "Parts Store"
Find Parts By Model
Search for Model, enter 1710
Select 1710 3 Cyl Compact Tractor
Front Axle & Steering
03F02 Power Steering Tubes 1510 & 1710
Here is an invoice I got from my local New Holland dealer. Parts are the 3 point hitch seal and o-rings, a gasket for the 4-wheel drive lever, and all the o-rings on the priority valve.
   / What is this and how do I fix it? #34
Thank you
   / What is this and how do I fix it? #37
Another question on this thread. I looked up the parts as eric suggested but total was 60 plus dollars!! Seems mighty steep for .50 cent O rings. Does anyone know the sizes I need to just order directly?
   / What is this and how do I fix it? #38
Might consider to buy a set of assorted metric Harbor Freight O-rings and try to match with the one you need replacing. If it works fine and if it doesn't then you are out of $10.
JC,
   / What is this and how do I fix it? #39
True, i guess i can try it! I wonder if those are rated for the hydo fluid.
   / What is this and how do I fix it? #40
They have both Viton and Nitrile for the same price. Viton would be a better.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
John Deere Z994R (A56469)
John Deere Z994R...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
