Comparison Branson 4225CH
/ Branson 4225CH #1
WillBuc59
Alabama
Branson 4225CH, JD870
I was going over my new tractor ( which I am loving) and found this:
A plug with two small holes and a bracket with two holes.
Just wondering what attaches to it...
/ Branson 4225CH #2
I've got a similar plug on my 8050 up by the left side mirror,
no idea what for!!
/ Branson 4225CH #4
I was going to say left-outside mirror since I didn't see one in the pic. Is that a connector hanging behind it? If so, may be for a CB radio antenna which farmers use/used before the advent of the cell phone. Course if their farm is outside the range of any towers the cell wouldn't be working anyway. Check your owners manual in the front sections where they detail this and that.
/ Branson 4225CH #5
Probably for the beacon. Some countries require beacons on tractors.
This is a picture from a Branson (older style) in Germany:
/ Branson 4225CH
Yep, I’d be willing to bet that’s it!
It’s just above the left side mirror.
Thanks!
/ Branson 4225CH #7
That makes sense as the connector seems to be a 2 connector 12v plug rather than a coaxial cable type that would be used with an RF antenna installation.
/ Branson 4225CH #8
They probably fit a switch in the cab upon installation of the beacon or does it come standard with the cab?
/ Branson 4225CH
I dont think mine has a switch for it, not sure where that wire leads to.
/ Branson 4225CH #10
Does it come on with the 4-way hazards, I wonder?
Mine has the same thing, but I've never investigated it.
/ Branson 4225CH #11
I happened to have my meter in my hand as I was walking past my 8050 so I stopped;
my connector hangs by the left mirror and has a steady 12 volts whenever the light switch is turned on,
not the flashers.
/ Branson 4225CH #13
not the flashers.
Would make adding a light bar or spotlight a bit easier.
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2019 Kia Optima FE Sedan (A61574)
2019 Kia Optima FE...
Champion Vibratory Roller (A60462)
Champion Vibratory...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
