dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,680
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
The hydraulic oil tank also features a very convenient sight glass just like the one
for the fuel tank. It is also a hefty 4mm-wall steel tank. The machine welds
look great.
The first photo here shows the tank and pump on the right side of the house
chassis, as it originally was made. The system features a steel mesh suction
filtration system, but no return-to-tank pressure filtration system. That was my
first major upgrade. Suction filtration is not a good solution to oil contamination
problems on any hydraulic equipment. The inlet screen looks like a 100-micron screen
without any bypass valve to avoid cavitation.
The filter chamber has a very nice large opening, sealed with an O-ring. This
allows inspection and cleaning of the tank. The suction filter is large, and even
comes with a Neodymium magnet attached.
I had to siphon out the hyd fluid before removing the tank since the drain plug
needs to be removed for clearance. Draining the oil thru the drain plug is not
easy unless the house is rotated to clear the tracks.
I bought a return filtration system from our friends at SurplusCenter, along with
a spare filter. Their Zinga 25GPM system features 10-micron filtration with a bypass
valve and 3/4" NPT threads. Only a bit over $30 for the manifold and 2 filters.
I chopped up a 3/4" steel pipe nipple to make the new bung hole in the tank.
Tho there was clearance to install the filter in a downward configuration, hidden
under the floorboard, I opted to install it so that it penetrated the floor for
easy replacement. This was an easy upgrade, and I am encouraging the factory
to make this change. I suspect that with 100u suction-only filtration, the life
of the pump will be limited to a few hundred hours.
look great.
